tiptronic stopped working..
So when I first got my 2006 c280 4matic the tiptronic worked fine.. Ive tried to put car into manual gear a handful of times since then and for some reason it wont work??? My shifter came loose and I used the "paperclip method"..maybe the shifter isent getting enough slack to reach the tiptronic????? what do you guys think? thanks
you need to find someone with DAS to define the problem---then you can fix-----all others is a load of HS!
