AC Compressor
Old Mar 27, 2018 | 02:40 AM
ljtigre's Avatar
c200 year 2000 (w203)
AC Compressor
Hi everyone,
I had a compressor issue with my AC, it was thus replaced with a used one. The AC guy couldnt get it to work through the panel and created a switch with its own fuse. The compressor burnt out after a few days, causing black oil, and a broken belt He replaced it again, but then discovered a condenser leak, and it now has to be replaced. Because I kinda lost faith in the guy, I pulled out my car, and will now buy a new condenser. And since there is a leak, I cannot use the AC and test the compressor. .
Question: Is it dangerous to have this separate switch? Can it cause the compressor to burn out, or perhaps something more crucial to the running of the car:
Note: I live in the Philippines, and the AC is crucial.
Any advice would be appreciated.
Thanks.
Old Mar 27, 2018 | 05:13 AM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
Yes, make the cars original control mechanism work and don't manually engage the AC compressor or you will keep burning things out.
