P2602 fault code on low mileage w203 (75000km), already replaced and tested alot
Old Apr 28, 2018 | 10:19 PM
dutz_bier's Avatar
Mercedes 1993 180e (190e 1.8), 2002 C180, 2006 sl350 3.5
Hi,
for the background info please see the following post:
http://www.benzworld.org/forums/w203...ggestions.html
basically had some broken wires in the shifter in Nov 2017, which caused fuse 55 to blow, and p2602 fault code. Since then alot of testing and work has been carried out but the fault will no go away.
I would like to know if the solenoids could still be faulty if ohm and click tests are good.
Thanks.
Old Apr 29, 2018 | 01:55 AM
Russell Ormerod's Avatar
not a merc
Put the original conductor plate back and retest
Old Apr 29, 2018 | 02:21 AM
dutz_bier's Avatar
I can't unfortunately, it was left at the mechanic who serviced in in Nov last year. I still have the chinese one, although the new mercedes one that's in the car currently should be good.
