Starter Motor removal
Old May 16, 2018 | 05:00 AM
Auscraig's Avatar
2003 C200 W203
Hi there. I'm hoping for a bit of help removing the starter motor from my 2003 C200 W203. I've removed the bolts and the one visible lead but there seems to be wiring going directly into the starter which I can't see because it's behind the area of vision. Any advice would be much appreciated. Thanks.
Old May 16, 2018 | 04:35 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
I'm guessing you have the M111 engine same as me.
Check my 2 video's here
on the starter. You can see there are 3 connections.
Each is a different size so new screwing up on the re-install.
Getting the top bolt is a beeeech, since you have to thread extensions from the back
of the trans. Guess you got that already.
Make sure the steering column is locked when you push that piece in and drop the steering shaft.
I also have a rather lengthy thread written probably around 2009-2010 or so,
where I post a bunch of info on the starter removal/repair etc. Just search my username and 'starter' in this forum in the
advanced search. Or it might be on benzworld. You will find it. All the Mercedes docs are in there too.
For me, I just cleaned it and replaced the brushes, but neglected to put grease in...
makes a horrible noise now...but what the heck, I'm at 240K miles.
Good luck!
Old May 16, 2018 | 09:38 PM
Auscraig's Avatar
2003 C200 W203
Thanks for taking the trouble to reply. I should have mentioned that my car is right hand drive so the steering column isn't a problem, nor is the exhaust as has been suggested on other forums. It just has a wire that by the feel of it, goes into the starter and that's stopping the removal. Cheers.
Old May 17, 2018 | 01:55 AM
W203E35's Avatar
2006 C350 Sport 6MT
Is it possible to get a picture of the wire? I've attached a PDF document. Take a look when you have a chance. It looks like just 2, 3 and 6
Forgot to circle 2 and 3
File Type: pdf
Last edited by W203E35; May 17, 2018 at 01:59 AM. Reason: Forgot to circle 2 and 3
Old May 17, 2018 | 03:10 AM
Auscraig's Avatar
2003 C200 W203
Success
Thank you for that. I finally got it out this afternoon. The problem was that there was a plastic casing around the cable and nut which had to be opened - but I couldn't see it. Thanks again for your help.
Old May 17, 2018 | 12:18 PM
W203E35's Avatar
2006 C350 Sport 6MT
Great! Glad you got it figured out.
Adding instructions for the m271, m272 and om611 in case any members needs them.
Thanks,
File Type: pdf
File Type: pdf
File Type: pdf
Old May 17, 2018 | 04:27 PM
Here''s my original thread, with a DIY written by me near the bottom.Forgot about those plastic caps.
https://mbworld.org/forums/c-class-w...ild-diy-2.html
