compressio - C240 W203
Old 10-08-2018, 07:19 AM
milooshev's Avatar
W203 C240 V6 2.6L
Hello, what should be the normal compression for 2,6L (gasoline) V6 engine? I have a problem with misfire in cylinder 5...
Thank you.
Old 10-08-2018, 07:28 AM
milooshev's Avatar
W203 C240 V6 2.6L
Hello, I just want to add some information:
The problem is "misfire in cyl. 5".
I am running on both gasoline and LPG. I have the same error on both fuels, so I logically exclude to be a fuel problem...
I changed the coils and the plug cables, changed the plugs (sparks) as well (both on cylinder 5). But still when I go over 4000 ppm the "check" sign goes on and the car starts to shake and loose power....
Any ideas would be very much appreciated.
Quick Reply: compressio - C240 W203
