2003 c240 4matic wagon fuel line broke neeed help!
Old Mar 29, 2019 | 08:58 PM
contact148's Avatar
changing my winter to summer tires today and I could smell gas at the LR wheel so I looked around and noticed the fuel filter was wet dropped the cover and sure enough the line that feeds the engine has rusted through ABOVE the fuel tank...
there is no way I am dropping it so I cut the fuel line just in front of the tank and flared the end I plan on buying rubber fuel line hose but I doubt I will be able to run it above the tank so it will have to go under unless one of you has a better idea
car has 200Km rusting pretty bad and I am NOT spending any more money on it car owes me nothing
in the pic its the line on the left looks braided
Old Mar 29, 2019 | 10:19 PM
tjts1's Avatar
C320
Have you considered opening up the fuel tank access cover below the rear seats?
Old Mar 29, 2019 | 10:42 PM
contact148's Avatar
yes I did that the line is not visible from there it runs between the round access door and the side of car only way I could see it is drop the tank and its WAY too much hassle on the 4matic
Old Mar 30, 2019 | 12:45 AM
tjts1's Avatar
C320
Well I guess you answered your own question. Good luck with car shopping.
Old Mar 30, 2019 | 12:39 PM
contact148's Avatar
well it was raining and 2C out this morning car was on driveway with no way to move it so I got wet really wet I was able to run a rubber line under/beside fuel tank from filter to line to engine proper fuel rate hose an clamps seems to be fine after 20km drive all fixed for $20.00 worth of hose and clamps
Old May 15, 2019 | 07:04 PM
dmp374's Avatar
c230
That's Awesome! I'm having the same problem on mine. my line is rusted by the fuel filter and is about to start leaking. My w203 has two fuel line that run down the side of the car. How did you know which one to run it to. I cant see over the tank. To see where it exits.
