Question about Command
Old May 3, 2002 | 12:29 PM
Silver_Lana's Avatar
When you are using your command system, can you move from one field to the other using the arrows on the Steering wheel?
I tried it on a coupe in the dealer showroom and it didnt work..
Any thoughts?
Old May 3, 2002 | 01:14 PM
Boo2's Avatar
C32 AMG
Nope, doesn't work. You can only control sound system and telephone functions after switching to that section yourself.................... But to tell you the truth, i haven't even read the manual yet!!!
Old May 3, 2002 | 02:41 PM
CHECKMATE's Avatar
C320 Sport Wagon
Cool Sub menus/fields
Good question-after a less than sterling briefing by the salesman on system operation, I have spent considerable time with and without manual in hand....and with help from folks on the board trying to sort out COMAND procedures. As far as I can determine, you can use the wheel + and - buttons to scroll thru sub menus displayed in the instrument cluster-for example the "settings" call up. However, moving thru the screen fields can only be done with the lower right function select toggle/knob. Good luck-not exactly intuitive, but fun to play with.
Old May 3, 2002 | 03:24 PM
Boo2's Avatar
C32 AMG
Re: Sub menus/fields
I think Silver-lana is talking about the COMMAND or navigation system.
Old May 3, 2002 | 03:44 PM
Re: Re: Sub menus/fields
I was..
Old May 3, 2002 | 04:10 PM
CHECKMATE's Avatar
C320 Sport Wagon
Unhappy So am I
What I was trying to explain is that the wheel control has some scrolling functions-but the Nav screen has to be moved thru the available fields with the control toggle. In short you can't move thru Nav field from the wheel.
