2004 C320 Sport - News/progress
Old May 7, 2020 | 01:51 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
As some of you are aware, I recently purchased a 2004 C320 Sport with 60K miles on the clock.
Here the previous thread, "BUYING ADVICE"
https://mbworld.org/forums/c-class-w...ng-advice.html
Decided to post all future updates about the car here in this thread.
Below pics just received from my Buddy in Long Beach, car is ready for the trip to its Final Destination here in Sacramento tomorrow.
Old May 10, 2020 | 11:28 PM
S70Houston's Avatar
Car has arrived as scheduled on Friday.
Today, my son and I took the time to give it a nice detail and wash.
What a mess, unbelievable to me each and every time I purchase a used car how peeps dirty up their cars. There must have been a Starbucks Cup of Latte spilled in there once, and not properly cleaned up, as it was a dirty, sticky mess.
Shampooed all Carpets, washed the seats and door panels, cleaned out the trunk and organized the tool kit, which was all over the place.
Car needs a few items addressed:
- Seems like the turn signal stalk is bad and must be replaced. Whenever you turn on the turnsignal, the wiper starts to wipe 3, 4 times.
Out of the blue, the windshield washer starts shooting water and the wipers go of as well. At least we know why the wiper fluid reservoir was empty.
- Passenger Front Wheel Well has the Splashguard Plastic Piece missing. Will order and attach.
- There are a few of the plastic push pins missing for the trunk liner. Will as well order and attach.
- Rear window tint needs to be redone.
Overall, I am pretty pleased with my purchase. Car drives and shifts as it should, rides awesome.
After the detail job, I took Junior and let him drive in an industrial area parking lot.
Old May 11, 2020 | 03:42 PM
BF_JC230's Avatar
2005 w203 C230
If the multifunction stalk is faulty, that usually requires replacement. A small plastic dedent tab breaks inside. Especially being pre face lift.
That will require steering wheel and clock spring removal, which is easily searchable.
Old May 11, 2020 | 03:53 PM
S70Houston's Avatar
Hopefully not too expensive.
Old May 11, 2020 | 06:07 PM
BF_JC230's Avatar
2005 w203 C230
If it’s broken/shorting wire related, you may be able to rebuild it.
I recall seeing a complete tear down and requirements post, step by step.
ensure you’re searching with the web browser, not the app.
Old May 11, 2020 | 10:59 PM
S70Houston's Avatar
Thanks for the info.
I will however let me trustworthy mechanic troubleshoot and take care of it.
Old May 13, 2020 | 09:33 PM
S70Houston's Avatar
MB Valve Stem Covers
Today, the first minor detail added to the car, Mercedes Benz Valve Stem Covers.
Old May 15, 2020 | 05:24 PM
5by5's Avatar
2011 C300 Sport 4matic, 2005 C240 4matic, 2003 C230K Sport, 1999 C230K Sport, 1969 220D (first car!)
$100-120 online.
I did this job on my daughter’s 2003 C230. Fiddly but straightforward. Hardest part was removing the steering wheel bolt. Really struggled until I got a HF Earthquake XT impact. It blasted it off.
I might have been able to fix the broken wire but I had already ordered the replacement.
I always plan to do a deep clean on a used car. Quality materials usually clean up well. It looks like a really nice car. Does your soon like it?
5
Old May 15, 2020 | 08:16 PM
S70Houston's Avatar
Originally Posted by 5by5
$100-120 online.
5
Thanks very much 5.
Car is currently at my trustworthy mechanic, who went through the car.
It is indeed the turnsignal stalk/lever causing the issues. Mechanic ordered a new stalk, which will hopefully be available on Monday.
Car needed an oil change, as Service A was due, it was also recommended to change/flush the brake fluid.
Other than that, he could not find anything wrong with the car. No leaks, nothing. So I am pretty happy with that!!!!!
YES, my son loves the car. He absolutely had to have a manual, so when I saw this deal, I had to get it for him.
Old May 16, 2020 | 05:57 AM
BF_JC230's Avatar
2005 w203 C230
Me too.
Dealer looked at me like I was crazy. Had to wait almost 4 months after I placed the order.
welcome to the ~3% club.
Old May 16, 2020 | 11:56 AM
S70Houston's Avatar
Me too.
SWEET!!!!!
Not sure where you are located, but try to find a used manual stick shift car in decent shape in CA, let alone a Mercedes.
Old May 16, 2020 | 12:32 PM
BF_JC230's Avatar
2005 w203 C230
And you have arguably the best non ///AMG engine.
I’m near Lake Erie, and ordered mine new.
Old May 16, 2020 | 12:34 PM
S70Houston's Avatar
How so?????
Old May 16, 2020 | 01:43 PM
tjts1's Avatar
C320
How so?????
The m112 V6 and m113 V8 twins are by far the most reliable, robust and easy to work on engines Mercedes ever made.
Old May 16, 2020 | 01:52 PM
S70Houston's Avatar
Good to know. 👍
Old May 16, 2020 | 06:05 PM
BF_JC230's Avatar
2005 w203 C230
And honestly: upgrading the interior can be on the cheap used if you go aftermarket head unit.
ChrisTheSweede and others have posted tons.
The upper control panel might need a new connector. Biggest change in electronics is the sunshade, if you have one.
HVAC the same thing.
Dash cluster should swap with a new/viginized eeprom unit. Coded to car, it should fire up. Only issue might be the fuel sending unit between facelift and original.
All trim swaps out.
a face lifted retrofit interior to that car and DANG.
Old May 16, 2020 | 06:21 PM
S70Houston's Avatar
All trim swaps out.
Sorry to disappoint you, but I am an OEM, leave it original kind of guy.
The interior of that car is pristine, the dash cluster has solid and crisp, like new pixels.
Seats as well are like new, so I will not be spending any monies on swapping anything.
If my son decides he wants a new head unit for it, he can buy one himself.
Old May 16, 2020 | 08:27 PM
BF_JC230's Avatar
2005 w203 C230
Agree.
With two kids myself I understand and support that. I had to buy my first car and it’s power plant.
I was more suggesting for a few bucks online he could bring the car up to a very contemporary interior with slight wire end changes, if you or he choose to. Don’t be afraid of it. Staying away from the MOST system and bypassing with a aftermarket head unit would certainly save massive amounts of frustration.
There are quite a few that look 80-85% OEM to the facelift.
Old May 18, 2020 | 08:35 PM
S70Houston's Avatar
Car came back from the mechanic today.
- New Turnsignal/Wiper Staulk
- Oil and Filter Change
- Brake Fluid Flush
- Missing Passenger side Front Fender Splash Guard installed.
Mechanic was all impressed about the condition of the car, and it being a manual.👍
So, all good for now, until we address the remaining cosmetical issues.
Old May 22, 2020 | 11:55 PM
S70Houston's Avatar
Today's progress:
- New Wiper Blades installed.
- Polished and waxed.
Old May 24, 2020 | 08:46 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
That's a good looking 203.
Old May 24, 2020 | 11:57 AM
S70Houston's Avatar
Thanks very much.
Old May 25, 2020 | 09:08 PM
S70Houston's Avatar
Another coat of wax today.
Old May 28, 2020 | 10:45 PM
S70Houston's Avatar
License Plates cleaned, new/current registration sticker applied, and new carbon fiber license plate frames installed.
Old May 29, 2020 | 05:59 PM
S70Houston's Avatar
Car unfortunately only came with one key, which is original. Old key is pretty cracked on the housing, so I ordered a new key from the Stealership, which I picked up today.
All that is left is to replace this ugly, bubbly tint on the vehicle. Also the rear bumper is needing some attention, as it is cracked on one side and sagging.
Once this is all addressed, I say the car will be as good as new, with currently only 60,084 miles on the clock.
