05 c owners need your help
I need a VIN from a car that is 2005 with ash gray interior. I need the VIN to enter into a parts catalog for a part number lookup. Any help is appreciated.
Goodluck on that one!
HaHa
Stock Number: 10225E VIN: [Masked] Classification: Sedan Exterior Color: Midnight blue Interior Color: Ash Sunman, can you look up the EPC for the parts that my friend needed if you had time? |
which parts were those? I think the auto levelling stuff right?
Yep, they said that they still couldn't find the PN for harnesses that run between the sensors and the lights, and not sure about the PNs for the sensors on the front and rear axles. Thank you so much for your help!
Grow Up !
Originally Posted by nicedeboy
HaHa
Carlos Saprissa@aol.com |
Kev04C320 and Sunman....
Check your PM's for a helpful suggestion |
Ok here goes.
Front axle sensor 010-542-7717 Mounting BOW 220-328-0226 Bracket front 203-542-01-40 Ball Pivot front 071803-010202 Rod Front 203-320-2489 Rear Plate 203-328-0035 Rear Rod 203-320-0589 sensor bracket 209-328-04-40 rear sensor 010-542-7717 bracket housing 203-320-03-43 MAIN HARNESS WITH FRONT AXLE HARNESS 203-540-86-06 left hand drive 203-540-8708 right hand drive rear axle harness 209-540-01-33 |
Ok here goes.
Front axle sensor 010-542-7717 Mounting BOW 220-328-0226 Bracket front 203-542-01-40 Ball Pivot front 071803-010202 Rod Front 203-320-2489 Rear Plate 203-328-0035 Rear Rod 203-320-0589 sensor bracket 209-328-04-40 rear sensor 010-542-7717 bracket housing 203-320-03-43 MAIN HARNESS WITH FRONT AXLE HARNESS 203-540-86-06 left hand drive 203-540-8708 right hand drive rear axle harness 209-540-01-33 By the way, did the VIN work? |
sunman is the man!
