The Truth about Netherlands Setting
Old Aug 10, 2004 | 03:30 PM
SUNILP's Avatar
2015 E250D
I played with a DAS system for several hours today. Many people wanted to make their car chirp with the remote. The only country you can set so it will enable chirping is the NETHERLANDS. But, you WILL LOSE PANIC Feature. I tried every single country on the list and NETHERLANDS is the only one that chirps. Steve must have something to do with this. Also, for those adding Interior Motion Sensor, the country has to be changed to MEXICO WITH INTERIOR MOTION SENSOR. I tested the sensor and it works great. THERE IS NO SETTING WITH CHIRP AND PANIC FEATURE TOGETHER. I checked everything in the DAS system with all settings. And trust me, there are a lot of settings!
Old Aug 10, 2004 | 04:00 PM
MarcusBenz's Avatar
'06 ML500 w/Apperance pkg & '07 SL550 w/AMG pkg
Sunman is correct, in fact, I just had my CLK switched to the Netherlands setting yesterday! It will make the car chirp when locking and unlocking, you will lose the panic feature, but the alarm will still activate as normal.
Old Aug 10, 2004 | 04:03 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
yes i have had the netherlands setting set on my car for about a year and a half and i like the beeping sound. i dont have to look back to see if the car has locked or not. i dont care about the panic button to much. doesnt bother me.
thanks for the input about the IMS sunman. if i do decide to get this then ill need the country setting then. sunamn can you send me some size specifications on the IMS. i want to make sure there is enough room between the glass on the pano roof.
Old Aug 10, 2004 | 04:35 PM
misterkomp's Avatar
C230 Kompressor Sport Sedan
Can I set my car to chirp even if I don't have the factory alarm on my car?
Old Aug 10, 2004 | 04:41 PM
did you buy your car in the US? if so then you have a factory alarm. and yes you can get it to chirp. take it to the dealer and have them change the setting. thats what i did.
Old Aug 10, 2004 | 04:53 PM
Wiedermann's Avatar
NA
Red face Netherlands setting
Here is a good one for Mr Sunman:
My E beast (AMG W211) does chirp and has the panic button enabled. That is how the car came from the manufacturer.
Wiedermann
Old Aug 10, 2004 | 04:55 PM
SUNILP's Avatar
2015 E250D
I have never played with the DAS hooked to a w211. If you say it does, then it must.
Old Aug 10, 2004 | 04:56 PM
misterkomp's Avatar
No I bought my car in Canada. Manitoba to be exact
Old Aug 10, 2004 | 05:12 PM
oh well then im not sure. i wouldnt think it would since there is no alarm. and the chirp comes from the alarm, or so it sounds.
Old Aug 10, 2004 | 05:19 PM
SUNILP's Avatar
2015 E250D
if you do not have an alarm then you cannot chirp. The sound comes from the alarm siren located behind the front right wheel under the plastic.
Old Aug 10, 2004 | 05:34 PM
wfb1746's Avatar
2005 C230WZ
dumb question:
do u guys like the chirp? i guess you wouldn't change it if you didn't, but just curious
Old Aug 10, 2004 | 05:37 PM
i like it. the reason i like it is because i was never sure if the car was locked and i would look back to see if the lights were flashing. or if i forgot to the car and was in the house i would walk to the car to see the lights flash. now i can stick my head out the door and listen for the chirp or while im walking away i hear the 3 chirps and know the car is locked. to me the audio is more helpful than just the visual effect of the blinking lights.
Old Aug 10, 2004 | 05:55 PM
pj230's Avatar
Unless this comes with the car, how you know the complete list of options that can be changed like this chirping sound?
Old Aug 10, 2004 | 06:23 PM
SUNILP's Avatar
2015 E250D
I personally don't like the chirp so mine is disabled. As for these weird options, most people will never know about them. I came acrross this by playing with a DAS system hooked to my car. The DAS system is at your dealer and most probably, the dealer will not let you play with it.
Old Aug 10, 2004 | 06:37 PM
BklynBenz's Avatar
CL500
when steve was in nyc i had him try to activate the chirp on my w208 and it wouldnt work. weird.
Old Aug 10, 2004 | 06:39 PM
BklynBenz's Avatar
CL500
Originally Posted by wfb1746
dumb question:
i wanted it because my windows are tinted really dark and i cant see the door pins if they are up or down from the outside. if i heard the chirps then i would know my car is locked and not have to second guess myself all the time.
Old Aug 10, 2004 | 07:16 PM
wfb1746's Avatar
2005 C230WZ
is the chirp pleasing to the ear or do u guys use it only for the practical purposes that have been mentioned?
Old Aug 10, 2004 | 07:20 PM
SUNILP's Avatar
2015 E250D
It's more like a beep. Like the lexus cars. As for 208, Not sure about that car. 208 and 210 have vacuum controlled door locks so they are very very hard to hear. 210 has a visual light confirmation so it's a bit easier with the red and green light on the rear view mirror facing outside.
Old Aug 10, 2004 | 07:36 PM
DL_AMG's Avatar
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
I have both my C-class set to Chip. They are great way to locate my car. :P They are a bit louder then other car maker's chip but I like it.
Old Aug 10, 2004 | 08:24 PM
pookie's Avatar
2013 c300 4matic, 2002 c240
1. does the chirp turn off the lights from blinking? i sort of want both chirp and blinking lights.
2. i don't know if this is true, but i remember a thread was made last year that had a member who had trouble with his alarm. when he got the car back, the car chirped and the panic button worked.
Old Aug 10, 2004 | 08:49 PM
oggle's Avatar
E320
LMAO Mexican car thieves.
Old Aug 10, 2004 | 09:29 PM
SUNILP's Avatar
2015 E250D
The lights blink with the chirps so 3 chirps to arm and 1 to disarm. I remember that thread also but it is impossible in the real world to do that. I have tried playing with the DAS system for several hours and it is not possible to do that. Must have been a glitch.
Old Aug 11, 2004 | 10:56 AM
i like the chirp for practical reasons. its not really pleasing to the ears, but then again i dont sit with my back to the front tire and continuously lock my car. chirp, chirp, chirp, chirp, chrip.......
Old Aug 11, 2004 | 05:42 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
One of the most common changes here in the Netherlands...GETTING RID OF THE ANNOYING CHIRP WHEN LOCKING THE CAR!
greetingz,
Old Aug 11, 2004 | 06:13 PM
lol! not surprising at all!
