Interior plastic decomposing
Old Aug 19, 2020 | 05:15 PM
BruzeF's Avatar
C320 wagon
A customer asks if anyone has had any problems with plastic interior parts decomposing and crumbling apart. Especially the storage compartment above the console and the plastic around the console area. Thanks
Old Aug 19, 2020 | 05:48 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
2004 C320 Sport, no issues whatsoever.
Old Aug 25, 2020 | 04:22 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
The main thing that has gone bad is everything with that "soft touch" rubberized compound, such as the volume knob on the radio. That stuff turns to goo over time. I went over all those surfaces with rubbing alcohol and got rid of it.
The other stuff that went bad on me was the seat trim (the large panels behind the adjustment knobs and hinges). The original plastic is some crappy ABS that turns brittle. The updated pieces from the dealer are made with a different (more flexible and noticeably tougher) grade of plastic. I've swapped out pieces as they broke on me.
The plastic tray below the radio is still immaculate if that's what you're asking.
Old Aug 26, 2020 | 01:35 PM
C280 Sport's Avatar
MB’s of all kinds.
01-04 will have that issue. However, there were some that have not. Very rare but they are the cream puffs like the one pictures above.
Old Aug 26, 2020 | 01:56 PM
S70Houston's Avatar
Originally Posted by C280 Sport
They are the cream puffs like the one pictures above.
Yes, with just barely 60K original miles on the clock, I would indeed consider my son's 2004 C320 to be a CREAM PUFF.
Old Aug 27, 2020 | 12:23 PM
BF_JC230's Avatar
2005 w203 C230
A factory fitted (OEM or not) sunshade and the OEM side blinds are a every summer add on.
Shoot, I use the front blind if out parked long in any sunny/uv weather...
https://mbworld.org/forums/c-class-w...ow-shades.html
Old Sep 11, 2020 | 08:21 PM
mi ko's Avatar
2003 C230 Kompressor Coupe
Yep! Absolutely same issues with my 2003 C230K. I just today replaced the storage cubby, which was a long time coming. Much better. It was an easy DIY job.
I lived in FL for a while and the car got a ton of sun, so the melting and degradation has been an issue for at least 4 years now.
Old Sep 11, 2020 | 08:30 PM
S70Houston's Avatar
Living in Northern CA, I ALWAYS put sunshades in the windshield when parking, rain or shine. I also slightly tint all of my cars to keep the UV Rays from getting to the interior.
Most people think that the sunshades are only to be used in the summer in order to keep the heat out. It is however not only the heat that tears up any interior, it is also the UV Rays that deteriorate plastics and leather. AND, ...... UV Rays exist any day, even if the sun does not exactly "shine".
