Help please
Old Mar 10, 2021 | 01:04 PM
Dan Williams's Avatar
c180 kompressor
Help please
Help needed please, front Sam/fuse box was wet after the car was sat up, now the near side headlight stays on unless I disconnect the battery, also a whole load of warnings on the dashboard.
If I buy a new Sam about £190 will this cure the problem?
Will I need to take the car to a dealer after I’ve fitted it to be programmed or is it plug and play ?
Old Mar 10, 2021 | 02:18 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Might be a sticky relay. I would try that swapping first. Otherwise you're looking at a new front SAM.
Old Mar 10, 2021 | 04:27 PM
c180 kompressor
hi thanks for the reply, do you know if a new Sam would need programming or can I just plug in and drive?
thanks mate
Old Mar 11, 2021 | 12:16 AM
slammer111's Avatar
I think it's a direct swap as long as the firmware version is the same. Maybe someone else can chime in.
Old Mar 12, 2021 | 01:21 PM
Russell Ormerod's Avatar
not a merc
No relay runs the lights. Change the sam Sometimes you may need to change coding to match the the car. But it will function either way
