(w203) 2005 c230 k sport sedan post control arm change issue
Old Apr 24, 2021 | 03:21 PM
Ahmed Khalfe's Avatar
2005 Mercedes c230 kompresser sport 2009 ML320 bluets
After changing my control arms the steering will not return to the center when I let it go. could it be the alignment?
Old Apr 24, 2021 | 07:24 PM
tjts1's Avatar
C320
Yes.
Old Apr 25, 2021 | 01:49 PM
BF_JC230's Avatar
2005 w203 C230
What control arm did you change?
Regardless-
Alignment it pretty guaranteed as long as you didn’t use a new eccentric pin kit, reused same bolt lobe location and torqued it all to spec under speed (drive) load, or, chained it down...you need a full tank of gas too, and the suspension has to be in drive mode. A full alignment should not be needed if you followed WIS, only a check.
I’d say a proper shop can help you.
Old Apr 27, 2021 | 12:05 AM
all solved !
I got an alignment and it was because the toe was off since I replaced both upper and lower on both sides the issue is now gone !
