C180 Kompressor AC idle problem
Old Jul 10, 2021 | 05:55 AM
chris1977's Avatar
C180 Kompressor 2004
Have a 2004 C180 kompressor AC wasn't working well so been re gassed that now works fine, but when at idle the car is fine until the AC is switched on then its gets a bit rough get some vibration though gear stick (note was doing same with low gas), as far as I understand the ecu should compensate for the extra load but isn't any ideas where to start looking for the fault?
