AshTray To USB Port Conversion!
Now My New Question Is Merely Just Suggestions, I Am Looking To Turn My Back Seat Center Console Ashtray Into USB Ports And If Possible One Outlet Port On One Side, Tied N Connected To The Cigarette Port In The Arm Rest Center Console Whereas Its Hidden. Ive Might Have DIscovered A Way To String The Wires Through By Drilling A Small Hole Into The Inside Of The Ashtray Holder Hidden. So This Area, I Might Have Solved, I Would Love Feedback, And Suggestions On The Best Way To Convert This Ashtray Into The Ports I Need To Slide It Back In When Not Needed. See Below For Photos.
Note: The Port Used Is For 200 Watts Only. No Need For More Than That. ✌.
Using Original Cig. Port For Use In ArmRest Compartment Without Sacrificing The Port Itself
Velcroed The Wiring To Stick.
Adapter USB-C Illustration.
The Universal USB Line. USB 2, N 3.
Now We Have More Space Since Removing The Original PhoneLine Tray Compartment.
Removed Original Tray Inside The Arm Rest Phone Compartment N Complete Removal Of PhoneLine To Install The Female USB Port Inside To Use For Any USB Attachments, And Then Created A Whole New Carpet Layout To Cover Over Details Surface For Looks.
The Cig Port For All Connections
Wiring Inside
Wiring Side With Velcro N Zip Ties
Ashtray Topview
Ashtray Frontview
Ashtray Backview
This Is The Ashtray Spot I Am Focused On
Finalized The Ashtray To USB Ports, Using Two Standard USB A's. And One Super Charge USB-A And One USB-C. Connected To The Cig Underneath The ArmRest Panel Wired Through The Outtake Air Vent. Close-Up.
Far-View Of The Ashtray To USB Tray.
Med-View Of The Ashtray To USB Tray.
Inside Where The Wires Go.
Where The Wire's Are Going, Had To Keep Two Loosened To Allow Tray To Open N Close Properly.
Open View In The Console Where The USB Wires Connect To.
Removed Velcroed Wire From Outside N Moved It Inside The Armrest Console From The Outtake Air Vent.
Last edited by RealChris; Nov 6, 2021 at 04:33 PM. Reason: Adding Updated Photo's.
https://mbworld.org/forums/c-class-w...-lights-3.html
Last edited by RealChris; Oct 30, 2021 at 02:11 PM. Reason: Adding Member Name I Am Replying Too! ✌
Personally I used the existing armrest wiring to add 5V USB power. The stock phone cradle wiring is much too thin to draw too much juice (I'd say 0.5-0.7A max) without a significant voltage drop (>0.25V), so I just use it to trickle charge my MP3 player. The main advantage of my setup is that the power isn't switched, so I can simply leave the mp3 player plugged in overnight and I'm good for the next few weeks of driving. Also the setup is fully reversible as I use the 10 pin RJ50 stock plug (the one that looks similar to Ethernet) as well. The setup was also capable of charging a 2000s era candy bar phone, but won't cut it for modern smartphones. I just use a low profile 2 port USB cigarette adapter next to the coin holder.
I Uploaded The Updated Photo's. Please Seek Them Out In The OP And Let Me Know What Ya Think! 😎
