2005 kompressor need help identifying wire (with pictures)
Old Jun 1, 2022 | 07:05 PM
redgr81's Avatar
c230
My dog ate through the wire. It got fixed. Then another animal got ahold of it. I live in the middle of nowhere. Anyway, I'm looking for any information on this wire. From what I can tell it powers the super charger. I'm looking to find out: what it is, what it does, can I buy a new one? If I can't get a new one any advice on repair would be appreciated.
Old Jun 1, 2022 | 08:20 PM
tkid's Avatar
C230K M271 CL203 2003 model
LOL.. that's a good variation on 'my dog ate my homework'!!
If you are talking about the cable covered in goop in your pic, that is the post-catalytic converter Oxygen sensor cable. If you follow it along, you will see it terminates into the back of the oxygen sensor on the exhaust pipe. From memory, there are 4 colour coded wires in this bundle, it should be easy to strip back and solder in whatever length of wire is missing,. just ensure the colours match end to end..
Good luck!
Old Jun 1, 2022 | 08:47 PM
redgr81's Avatar
c230
Good luck!
Thats the wire. My step dad coated the wire in silicone the first time, yeah its a mess.
Old Jun 2, 2022 | 07:51 AM
tkid's Avatar
Cool.. If the oxygen sensor has never been replaced, it might be a good idea to simply buy a new sensor to replace it? Save on having to repair the cable.. They are not cheap though!
https://www.rockauto.com/en/moreinfo...5132&jsn=10487
Old Jun 2, 2022 | 06:41 PM
redgr81's Avatar
c230
Thanks for the link. Yeah im gonna just buy the whole thing. Can you explain why this wire being shorted out affects the power of the car? (Basically since the wire have been broken my super charger does nothing)
Old Jun 2, 2022 | 07:45 PM
tkid's Avatar
It should have some effect as its providing data to the ECU about oxygen levels in the exhaust after the catalytic convertor has done its job.
But, the more serious issue, depending what's happened, the wires could be shorted between themselves, and could have blown a fuse, or maybe damaged the electronics/ ECU??..
There are 2 x white wires that provide power for the heating element in the sensor, and 2 x coloured wires that transport the signal information.
**Strip back the wiring and ensure there is no cross-connection between any exposed wires!**
If there has been, potentially you could be looking at permanent damage to the electronics/ ECU of the car..!!??
Old Jun 2, 2022 | 09:33 PM
redgr81's Avatar
c230
Thank you for all the advice. Im pretty confident no cross connections. I dont think I spliced a wire very well the connectors I was using were a little to big. I have always had a weird electrical issue with the car tho and this wire being non functioning seems to make it happen more. I get a "display malfunction" waring: what happens is my turn single will be on going click, click, click *turn signal sounds* so then it will stop clicking and the green arrow stops for a second, display malfuncation pops up, then the turn signal goes back to normal click click click. Its like it pauses for a second. The other odd one is the high beam and break light will come on, display malfuncation, then they turn off. Anytime you turn the car off and start the display malfunction disappears and everything is fine. I bought the car 3 years ago and its always done this. Its not often but 1 or 2 times every few weeks. With the wire not working it happens maybe every other day maybe less. Never been able to figure this out, almost like its a power surge. Idk
Sorry got long
Old Jun 3, 2022 | 01:11 AM
tkid's Avatar
I have never heard of those issues on this model; you might want to start a new thread for that issue with the indicators?
i don't see how it could be related in any way with the oxygen sensor?..
Also, you really should get an OBD reader, so you can read the error codes off the ECU; that will help you a lot with diagnostics..
This car does have a lot of electrical/electronic parts, and they do play up a fair bit!.
