07 C280 Hesitation
Old Jun 18, 2022 | 01:00 PM
bkmech's Avatar
C 280
07 C280 Hesitation
Hi Have a 07 C280. When I accelerate hard and quickly I get a hesitation. Then slowly engine RPMs pick up and car takes off If I accelerate slowly and smoothly car responds and accelerates. I get no codes connected scanner no pending codes. Would a faulty magnetic cam sensor do this?
Old Aug 3, 2022 | 01:21 AM
vudka's Avatar
2007 C280 4matic Avantgarde (Canadian version)
I had the same problem at around 40'000km for the first time on a cold winter morning. The problem is sporadic (1/month). That summer, I changed my engine air filter, clean the MAF sensor and started to use LiquiMoly Fuel Injector cleaner. The latter seem to help a lot. Probably, I will eventually have to change the fuel filter/pump assembly (80'000km/4 years).
