W203 water tank
Old Sep 25, 2022 | 05:19 AM
dosti's Avatar
w203
W203 water tank
W203 2005
i have a problem with c class w203 2005.
water tank show on monitor. Tha water level is ok. Car dont het hot. The temperature is normal. I have changed sensor of water tank, the tank. Washer sensor. The water tank signa sometime show sometime no. Can anyone help me with that?
Old Sep 26, 2022 | 10:10 AM
hudsongt500's Avatar
2005 C230 Sedan 1.8K
Not exactly sure what your issue is. If you are slowly losing coolant with no signs of it on the ground, you may search for a leak in the the line that runs from the reservoir to the engine or the coolant pipe that runs the length of the engine right above the exhaust manifold. You may only notice it with the car running as a small leak in one of these places can boil/evaporate on the exhaust before it hits the ground.
Old Sep 26, 2022 | 09:02 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Which model W203 do you have? You might want to put that into your signature, as well as which country you're in.
If you have the M271 I4 engine (C180, C200, C230), the plastic coolant pipes are known to go bad. I'd look here, as well as the wiring to your expansion tank coolant sensor.
Old Oct 3, 2022 | 08:44 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
W203 confuses coolant low with windshield washer level sometimes. Check both.
