Help!, weird noise after C32 Brake Install
Old Oct 15, 2004 | 04:21 PM
czachari's Avatar
2003 C230
Had 18 inch Konig Imagine, those came with hubcentric rings. I installed the brakes and unortunately, the calipers rubbed for about 1-2mm. I bought a pair of H&R 5mm hubcentric spacers. Those did the job. Now the car drives fine most of the time but on fast left-right transitions (zig zag) the driver's side make a "clang clang" noise when the car is going to the right. I thought I did everything right. My suspicion is that the hubcentric ring may not be sitting flush on the spacer? I tightened the lug nuts to 82 lbs.
Any idea guys?
CZ
Old Oct 15, 2004 | 06:11 PM
czachari's Avatar
2003 C230
One more test drive
Well, after one more test drive it seems that the noise is happening strictly on right turns at speeds of 5-15mph or so. Turning the wheel all the way to the right while stationary produces no noise.
CZ
Old Oct 15, 2004 | 10:57 PM
W0n6_3d4n's Avatar
C200K (w204)
It could be a cable touching the driveshaft, a coincidence after you installed the brakes.
