AMG brakes installed finally
2015 E250D
I finally installed my AMG brake kit which was sitting in my closet for a long time. I did the job myself. Took me 2 hours for both sides. Took lots of pictures. There will be a complete HOW TO write up with pictures on www.installuniversity.com
NA
If you can, post all the info and pictures here on the board
Cheers!
Wiedermann
Can't wait to write it up Sunil. Now get to work on the trunk closer mod.
Eric
Eric
Originally Posted by CitronC230K_03
i can tell you when i replaced my brakes with AMG there was a definate increase in stopping power.
1 Post
2003 Citron Green C230KMT
Originally Posted by vadim
Did you actually measure it? Or is it just the feel?
no i havent actually mearsured it, but it does feel alot harder. also when going like 90mph on the freeway and getting on an offramp, then hitting the brakes, they seem to really make a difference. im not sure how big of a difference, but there really seems to be one there. the rotors and calipers are alot larger than the stock one from the coupe.
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Good job SUNMAN !
AMG Brembo's are nice looking, and like CitronC230K_03 says, you can definitely feel the difference. Maybe because we both drive COUPES, the increased braking-power feel is greater, compared to the stock MB brakes. I never measured the braking distance at a set speed with my stock MB brakes; I guess I could use what MB says they are from their specs sheet. Then I would have to go out and test, with the same factors of speed & distance, with my AMG C32 brakes.
Carlos
Saprissa@aol.com
Carlos
Saprissa@aol.com
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
On the coupe with so much breaking power in the front, the rear stays in rigth way when braking???
It wasn't better install the AMG rear brakes too (C30 cdi) ???
For me, I haven't noticed any adverse issues due to the
lesser rears. ESP takes care of that anyway. The increase in braking is most noticeable at high speeds (push hard on the straight, then boom, back down to 30 or 40 as you enter the corner) and when driving hard with constant braking, don't fade. For a time, I was commuting on mountainous backroads, and really came to appreciate the AMG's over stock. Daily straight line driving you won't notice them much.
You do notice the rotors adding to the momentum of the wheels, since they weigh like 30-40 lbs each. You feel it, like gyro's on the front the wheels.
I am working on it right now but I have had a few things come up and I am behind quite a bit.
I will try to have it up by next week.
Eric
Eric
Originally Posted by Sunman
I did not notice a significant difference at all except for the better looking calipers.
Originally Posted by rubensans
Time to chrome calipers?
2015 E250D
I use a can of CRC Brake Kleen. It's good stuff and evaporates fast. I don't use it all the time though. For anyone who is interested, the write up is almost done on Eric's site. http://www.installuniversity.com/mb/...brake_drsp.htm
Brabus K3
Nice Write Up. Thanks.
I will be doing it at final of the next week; I expect the write be completed ;-).
Can you post a pic of the sensor and the inverted torx?
Best Regards.
Ruben.
Best Regards.
Ruben.
Brabus K3
Delantero + Rueda:
Delantero Solo:
Latiguillos:
Traseros:
Sensor Desgaste:
Final:
More: http://www.mbklasse.com/forums/showt...&threadid=8578
Best Regards,
Ruben.
Delantero Solo:
Latiguillos:
Traseros:
Sensor Desgaste:
Final:
Best Regards,
Ruben.
