Transmission Issues
Old Oct 16, 2023 | 10:51 PM
blakemcelroy58's Avatar
2006 C230 Sport
Transmission Issues
Hey all, bought a 06 C230 Sport (722.9 7 speed auto) that had a bad turbine speed sensor and was stuck in limp mode. Dropped the valve body, sent the conductor plate off to Circuit Board Medics to be repaired and flashed. Reinstalled, and now getting code 0778, and sometimes 2716, telling me that the electrical check of solenoids Y38Y4 and Y38Y5 have failed. As these codes were not present before the attempted repair, I am wondering if I accidentally switched the positions of these two solenoids while reinstalling, as they are both black tops. Are they interchangeable or do they have different part numbers despite both being blacktops? Thanks
Old Oct 18, 2023 | 12:39 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Each valve is bench tested at the factory and the values written into the EEPROM somewhere. I think these things aren't even switchable between transmissions of the same model. I'd try switching them.
Old Oct 18, 2023 | 01:57 AM
2006 C230 Sport
Thanks! Ill give it a shot. Was very distracted and rushed putting the plate back on, so theres a very high possibility I switched them around.
Old Oct 19, 2023 | 02:29 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
I have rebuilt many of these transmission and we have done thousands of conductor plates in the last 18 years. So with confidence I am going to say this............ The trans solenoids in the 722.9 transmission ARE interchangeable. The eeprom contains flow data and adaptations data but do not have anything specific to solenoids. So you can reinstall them in any position. Also, electrical faults for solenoid connection is the second most common problem on these plates. This is why we always recommend to install remanufactured ones from Mercedes.
Old Oct 19, 2023 | 03:09 AM
2006 C230 Sport
Well, got underneath the car to drop the pan and look at the solenoids today, and there was basically no fluid in the pan! The level tube (the little plastic tube that clicks onto the drain plug hole must’ve become dislodged when I was installing it, making it so I had way less fluid than I thought. Dropped the pan and didn’t see any evidence of damage, luckily I only drove the car down the street. Going to top it up following the temperature procedure and make sure the tube is in place this time. Can I be fairly positive that this low level was causing the solenoid codes?
