starts and immediately dies
Old May 20, 2024 | 03:02 PM
freeonline's Avatar
c240
Question starts and immediately dies
2003 c240 base
sat outside in the snow for a week and now doesnt stay running
starts and immediately turns off
fuel pressure goes up to 55 upon start up, then back down to 20 after car dies
ive used 3 scanners and no codes
ive replaced with new parts
-fuel pump assembly
-fuel pump relay
-fuel filter
-battery
-camshaft position sensor
-throttle body (used part)
1/4 tank of new gas
im real clueless what to look at next
fuel injectors??
how can i check exhaust is working correctly?
Old May 20, 2024 | 04:00 PM
PeterUbers's Avatar
Originally Posted by freeonline
2003 c240 base
-fuel pump assembly
-fuel pump relay
-fuel filter
-battery
1/4 tank of new gas
fuel injectors??
leak test .... and MAF (but would expect code), is there a massive vacuum leak at one of the plugs or manifold or exhaust joints....
what's the battery life ... time for a change?
Old May 20, 2024 | 04:32 PM
freeonline's Avatar
c240
how do i test for a leak? or for a vacuum leak?
the battery is less than a year, ive charged it once or twice since this but seems to hold charge
Old May 21, 2024 | 07:42 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Did you get a reputable brand fuel filter? Aftermarket fuel filters are known for causing problems. I would only use the dealer or Mahle/Knect KL-82 filters.
I assume your car uses the same fuel filter as mine (C230). The filter has a built in pressure relief valve, which keeps the filter at maximum 55psi. Aftermarket filters are known to have faulty valves, which may explain your low pressure.
Of course the other option is to look at the fuel pump. Did you reconnect all the hoses correctly? As in the hoses inside the tank, between the L and R sides.
Old May 22, 2024 | 01:52 PM
freeonline's Avatar
c240
i got the cheapest fuel filter from oreillys lol this car was junk before this. whoever owned it did not take care of it. ive looked at the assembly a couple times to make sure those top and bottom hoses and the sensor are attached
Old May 22, 2024 | 03:09 PM
TheRotaryFox's Avatar
2002 C230K SportCoupe
The cheapest from O Reillys???
That might be your problem.
Get an OEM or OE one from FCP Euro or Rockauto.
If the car was junk before, make sure to check everything.
My friend has been having this issue on his 99 Maxima, I'll let you know what his issue is once we fix it.
What he does is once he starts the car he mashes on the throttle to keep it alive and then it runs fine.
Try that.
