Axle removal for a Starter replacement?
Old Nov 27, 2024 | 08:51 PM
Erratic4matic's Avatar
Hi, normally I do all my own repairs but this time I sent my 2005 c240 4matic to a very reputable shop for a starter replacement.
Prior to sending it i did a fair amount of research into the process of doing the replacement and I never saw anything that involved removing one of the front axles but the shop is saying this is part of the job. Has anyone else ran into this?
Old Nov 30, 2024 | 10:47 PM
Petethepug's Avatar
90 VW Corrado g60, 07 New Beetle Vert triple white & 09 Escalade ESV Plat LOL!
It was probably remove the entire exhaust per the factory but your tech knew removing the axle was a better shot. Exhaust systems get brittle and full of surprises after so many heat cycles.
Old Dec 1, 2024 | 03:21 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
4matic's I usually pull the exhaust to do the engine mount on that side, so the starters BASICALLY there. That checks out. The axle removal isn't as brutal as you think it is. On a good day it's sub-hour to me... and boy do 4matic cars involve pulling that specific axle for like 3-4 different services.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
