rear shock clunk
Old Dec 29, 2024 | 09:20 PM
bones774's Avatar
c320
rear shock clunk
I swapped out my rear shock, drivers side. The job went simply enough, didn't encounter any problems except now i have a clunk noise when i hit bumps. Is there something that i couldve overlooked? Done plenty of shocks before straightforward removal and reinstall/ Any help please? Thanks
Old Dec 30, 2024 | 02:02 PM
KevinH2000's Avatar
2005 C230 Sport Sedan-6 Speed Manual
Here are a few thoughts:
It looks like you only replaced one shock. The guidance I've seen recommends that they be replaced in pairs. Is there a difference in the replacement shock and the one that you didn't replace?
Is it possible that the shock is not fully tightened? I replaced my shocks about a year ago and I recall that after the car settled for a while that I was able to tighten it a few more turns.
Old Dec 31, 2024 | 02:15 PM
VenomX's Avatar
W203 C240
I have a similar thing. Annoying clunk at the rear, replaced shocks and noise completely gone.
All ok for a few weeks now I have an odd noise when hitting bumps but only from the rear left.
I will check the lower bolt which screws into the subframe when I get a chance. The top nuts are fine.
What manufacturer shock did you use ?
Old Jan 1, 2025 | 09:22 PM
Petethepug's Avatar
90 VW Corrado g60, 07 New Beetle Vert triple white & 09 Escalade ESV Plat LOL!
This is a good question. The next question is what occurs on these cars when new and worn shocks are run together?
Old Jan 1, 2025 | 09:42 PM
KevinH2000's Avatar
What manufacturer shock did you use?
I used Bilstein, B4's on mine. Bilstein B4's are meant to be equivalent to the OE factory shocks for the vehicle. I considered installing Bilstein B6's for a firmer ride, but I decided the factory sport suspension on my car was a good compromise between comfort and handling.
This link leads to a discussion of B4 vs B6 vs B8.
Old Jan 2, 2025 | 11:13 AM
Petethepug's Avatar
@bones774 did ya get caught up in a New Years bender?
