Kompressor Differences?
Old Mar 16, 2025 | 12:18 PM
ChicagoDog's Avatar
300C, XJ, E36, 2002
Hey Guys,
I need some expert insight into the superchargers on the C180K, C200K and C230K...
From research, found a few different part numbers:
- A271 090 26 80 (?)
- A271 090 20 80 (C180K, C200K)
- A271 090 21 80 (C230K)
If I understand correctly it may be that the case that the A2710902180 (C230K) was designed to create more compression as it was to be paired with the lower compression-ratio engine (8.7:1) in the C230K. Is this true? If so, how is the additional compression attained. By pulley or internally?)
Thanks for any help!
