Door Check Straps
So I've been ignoring the click and creaking noise my door check straps are currently making but now Im at the point that I need to fix the noise...
Has any fixed the clicking and creaking noises of the check straps? Yes I tightened the bolts and I've added some lubricants on the exterior portion im assuming the lube needs to go inside?
Thank you
Thank you
Not sure if it helps but I found just replacing them with a set from the junkyard fixed me right up.
new and one used since they were no longer holding the door.
Looks like you can still buy them.
