2005 C230 Kompressor Sport Sedan - Manual vs Auto Driver Impressions
If youre going with the supercharged 1.8, get the stick. The auto saps some life out of this engine, and autostick is kinda silly IMHO. The tranny still does pretty much what it wants anyway.
I think it is stupid how you move the stick left/right to shift gears. Isn't front/back more intuitive? Since it's all electrical anyway, I'd prefer steering column paddles!
If anyone else has tried their or similar tip-tronic system, you know what I'm talking about.
Say you are in the MB, you have it in 3rd gear using touch-shift, and you slow down or stop...it still displays 3 in the gear indicator, meaning that when you start again, it'll upshift from 1st to 2nd then from 2nd to 3rd and it'll keep it in 3rd gear till either you slow down and it needs to downshift or you upshift. But when you do slow down enough that warrants for a downshift, it won't change the gear indicator to 2nd year, it keeps it at 3, which says highest gear it'll upshift to.
In the Audi, same situation, your in 3rd and you slow down enough that the computer says you are at too low of a RPM for 3rd gear and it'll downshift to 2nd like the MB, but it'll acutally display 2nd gear on the indicator and then when you fully stop, it'll display 1st gear. Then when you start again, you are in 1st gear and will not shift out of it until you manually do so...but with the MB, you are able to go up to 3rd gear where it shifts through 1st and 2nd for you then stays at 3rd.
Also another cool feature of the tip-tronic is that it'll actually "blip" the throttle for you when downshifting manually so that it's a much smoother downshift and transistion through the shift, no jerking.
Has MB changed the way they do touch-shift in terms of what I said above? Or is it still the same as when it first came out?
, also, if you have it in tip-tronic and try to redline it, it'll automatically up-shift for you, unlike some other cars that let you ride the redline like there's no tomorrow, while i understand why they would do this so you dont mess up your engine, doesn't it kind of defeat the purpose of 'simulating' a manual and giving you more control if they're just going to take it away from you like this??? wonder if there will be some kind of upgrade to change all of this later or something
wishful thinking i'm sure, but a guy can dream can't he?
For those of you hating this discussion, learn to drive a stick for Pete's sake. You'll understand why we dis the auto, no matter how good it is.
After all, if you can't crank start your own engine you shouldn't be driving in the first place.
Since I have a manual transmission, I don't need the starter. I can pop start it.
Youre stuck at home with the slushbox. :p
