Alignment results - opinions wanted
Camber
Front Left
Before: -0.3 After: -0.9 (actually worsened...seems screwy)
Front Right
Before: -1.1 After: -0.6
Front Cross Camber
Before: +0.8 After: -0.3
Rear Left
Before: -0.5 After: -1.3 (again...worse than before!)
Rear Right
Before: -2.1 After: -1.5
Rear Cross Camber
Before: +1.6 After: +0.2 (should this still be positive afterward?)
Caster
Front Left
Before: +9.9 After: +9.9
Front Right
Before: +11.6 After: +11.6
Front Cross Caster
Before: -1.7 After: -1.7
(The tech says that caster cannot be adjusted, and is not measured in the rear. I'm not really sure what these numbers mean and whether or not he is fulla **** or not. Please advise.)
Toe
Front Left
Before: +0.07 After: +0.17
Front Right
Before: +0.0 After: +0.17
Front Total Toe
Before: +0.07 After: +0.34
Rear Left
Before: +0.37 After: +0.34
Rear Right
Before: -0.04 After: +0.25
Rear Total Toe
Before: +0.33 After: +0.59
Rear Thrust Angle
Before: +0.21 After: +0.05 (not sure what this is a measure of)
My suspension set-up is H&R cupkit w/ half spring coil cut in front and #4 spring pads in rear. I was assured that they were performing a full 4 wheel alignment, with camber and toe adjustment. As previously mentioned, they said that caster could not be adjusted. I'm just a bit skeptical because the entire process took just about an hour and some of the results are confusing. If anything was done incorrectly I would rather take it back and have it fixed ASAP. The alignment comes with a 6 month/6k mile warranty, so I intend to go back and have it redone for free before that runs out anyway. The total cost was $117.89, which was pretty good based on what I had been quoted at several shops in the area, but I just want to make sure they actually did a good job. The ride felt fine before and feels basically the same now, but I wanted to make sure and get alignment done after lowering the car and letting the springs set. Thanks in advance guys!
