Old Jun 29, 2015, 03:16 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Driver Side Window on an SS? Cost? Replacement?
Old Jan 8, 2005 | 03:54 AM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
Hi guys, I don't know if you've seen this thread, but here it is https://mbworld.org/forums/showthrea...579#post980579
I need to replace my driver side window, any suggestions? Thanks.
Old Jan 8, 2005 | 11:44 AM
mick1's Avatar
2005 C320wz
that sucks. you need a window with the same amount of blue tint to match the rest of the other windows otherwise, the new window will look different from rest.
Old Jan 8, 2005 | 11:50 AM
nlpamg's Avatar
I called up the parts dept. of my dealership, it's $100 ($75 cost). Now it's just a matter of how much they'll charge me for the install. I called some other dealerships and they're saying $200, my dealership hasn't responded yet...
Old Jan 8, 2005 | 12:58 PM
wblynch's Avatar
2008 c350 SG - 2004 c240 Wagon BS
Keep us posted.
I'd be interested to know what happens.
I need to replace the passenger window on Wifey's new 240 because her friend scratched the crap out of it with her diamond ring.
Good luck
Old Jan 8, 2005 | 03:05 PM
Capt Nemo o2's Avatar
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
Generally speaking, the side windows are fairly straigt foward to replace. The hardest part is getting off the interior door panel. Once it's off there is another steel panel in which the speakers, door panel, window tracks and regulators are attached to. On this panel should be openings that when you move the window up and down you'll see two screws move by. These are the screws for the clamps that hold the window in. In your case, it might be better to take off the inner steel panel to vacuum up all the broken glass. (Broken glass has a tendency to show up years later, if some one sees broken glass, they assume an accident.) Once the panel is back on, slip the new window into the track. with the window in the clamps, raise the window up to make sure its in the right spot. Tighten the clamps and put everything back. If you have any mechanical ability its pretty simple.
Old Jan 9, 2005 | 02:13 PM
wblynch's Avatar
Capt Nemo o2, thanks for the great description.
I'm a dyi kinda guy so I think I'll give it a shot.
