Lorinser tunes C class ... interesting item buried in the BS
http://jalopnik.com/cars/tuners/lori...chy-333087.php
Normal yadda yadda from an overpriced self important tuner that barely translates to english. But the interesting take away is the mention of the 350 making over 300hp without FI " <refering to the c200 kompressor> ... This added power is achieved by installing a modified engine control unit along with altered belt pulleys, drive belts and a different air filter. The C 350 with its six-cylinder V engine can also be optimised. This model also features modified camshafts. The performance is increased from 200 kW/272 hp to 224 kW/305 hp, while the torque jumps from 350 Nm to astounding 380 Nm." What's not clear is if it's just cams or if it's cams in addition to the pulley and air filter ... but that's still not a lot of work. Evidence that just around the corner the 3.5 V6 will be making better #'s from the factory? :nix: |
how much more gas will this use when i have 305 hp?
That's kind of determined by your right foot. :naughty:
I want the engine upgrade for the C200K, sounds delicious!!
Originally Posted by oblu
(Post 2551276)
Uh ... duh? ... of course it will; by how much? :nix: Anybody's guess.
Only 2 ways to make more power. More air allowing the engine to burn more fuel, and more revs which burns more fuel over time. |
(Post 2551562)
Originally Posted by tanktube67
(Post 2552603)
^How you explain :confused: BMW 335i 300hp 19/28 mpg that's engineering :smash:
(Post 2552603)
Not really ... it's called Forced Induction. |
