New 305hp/265lb 350 engine unveiled?
05 CLK 320
I saw this in the SLK press release. I wonder if this is making it to the C-Class and if there are going to be differences ? Fuel consumption ?
"Fast-running sports engine: higher output and much lower fuel consumption
The sporty credentials of the 2008 SLK generation are further enhanced by three modified powerplants that consume less fuel and, therefore, emit less CO2. The four-cylinder powerplant in the SLK 200 Kompressor and the six-cylinder sports engine in the SLK 350 both offer substantially more power and torque. Only the SLK 55 AMG retains its familiar engine – an eight-cylinder unit that has lost none of its mesmerising performance capability and remains a unique selling point in the SLK segment.
The Mercedes-Benz engineers paid special attention to the fast-running V6 sports engine that makes its debut in the new-generation SLK, totally altering the six-cylinder unit's character by making sweeping changes to the mechanical setup. Although the displacement remains the same at 3498 cc, the engine now develops 224 kW/305 hp at 6500 rpm – some 24 kW (33 hp) more than its predecessor. The peak torque has also been boosted, by 10 Nm, and now stands at 360 Nm when the engine is running at 4900 rpm.
This result was achieved by raising the engine speed limit to 6800 rpm; it can even be increased to 7200 rpm for a brief period – oil temperature and other engine parameters permitting. Other changes introduced include a higher compression ratio, a new intake manifold and an extensively modified valve train.
Further aspects which add to the emotionally charged appeal of the new engine include deliberately powerful sports-engine acoustics with a strikingly emotive sound design when decelerating. In combination with the 7G?TRONIC automatic transmission, the engine management system also blips the throttle automatically during downshifts. As well as producing an extremely sporty sound, this throttle-blipping function reduces load alteration effects.
Despite the higher output and high-calibre performance, the SLK 350 consumes considerably less fuel. With the six-speed manual transmission on board, combined fuel consumption is just 29.7 mpg; if the 7G-TRONIC automatic transmission is fitted, the sports powerplant returns a combined fuel consumption of just 30.7 mpg. Lower fuel consumption means that CO2 emissions are also reduced – by 23 g/km to 219 g/km in the automatic version and by 28 g/km to 227 g/km in the manual version."
from germancarzone.com
05 CLK 320
Administrator
This cracks me up. STFF & Closed
