Need help pairing my Blackberry Pearl
I've been trying to pair my blackberry to my C300, but having no luck. This is my second blackberry pearl. The first one paired fine and had no issues, but that phone was stolen. Got a new pearl, but having problems pairing. I think the security code is 0000's. Anyone have any suggestions?
enter the code on the phone and the keypad on the dash. That is how I did it.
Originally Posted by ShoremNJ
(Post 2741806)
this worked for me:
1) scroll to phone using your steering wheel buttons(that would be left arrow 3 times i think) 2) go to setup on your command screen 3) go to bluetooth 4)dont click find phone. move over to options and click it. 5) select outside discovery 6) find the car using your phones bluetooth connection then type your passwords *I am not sure if these are the exact titles of the options, b/c i am not in my car hope this helps |
Originally Posted by theraj2
(Post 2741889)
this worked for me:
1) scroll to phone using your steering wheel buttons(that would be left arrow 3 times i think) 2) go to setup on your command screen 3) go to bluetooth 4)dont click find phone. move over to options and click it. 5) select outside discovery 6) find the car using your phones bluetooth connection then type your passwords *I am not sure if these are the exact titles of the options, b/c i am not in my car hope this helps +1 :y Worked for my BB 8820... can't pair any other way except using this method. THANK YOU!!! |
(Post 2741889)
this worked for me:
1) scroll to phone using your steering wheel buttons(that would be left arrow 3 times i think) 2) go to setup on your command screen 3) go to bluetooth 4)dont click find phone. move over to options and click it. 5) select outside discovery 6) find the car using your phones bluetooth connection then type your passwords *I am not sure if these are the exact titles of the options, b/c i am not in my car hope this helps Tried the above, but on step 4, I dont have the option to move over to "option" and click it. The only thing available is just the Update button and when I select that it searches for a bluetooth. My phone will prompt for the security code and I tried the following numbers with no luck: 0000, 00000, 1234, 12345, 0123. It'll try to pair, but always comes up with the message: "Unable to Pair with MB." Anyone else have any other suggestions? Starting to think my phone will not work. |
Here is a direct link to the pairing process for the Pearl (PDF)
http://www.mbusa-mobile.com/get_manu...nload.php?id=2 |
tight! :)
Originally Posted by slp0313
(Post 2744193)
Anyone else have any other suggestions? Starting to think my phone will not work. Until I figure it out... Honestly... it took me a while to figure out step 4... the option menu is not not very visible and kind of faded with the background... when you are on the "update" menu, shift the "mouse" or the control knob to the right (not scroll or turn the knb, rather push the control knob to the right... "Option" is now highlighted... click the the control knob... you will now see the "outside discovery" Then both your phone and COMAND screen will prompt you with a passcode. Now you can pick any passcode (min. 4 digits) for your device pairing. Make sure that both your phone and COMAND have the same passcode... (unlike the process of pairing with other bluetooth device, you don't have to use the default BB code which is 00000) |
Originally Posted by itcrashed
(Post 2744367)
