Door lock pins-AGAIN
Old 08-06-2008, 01:27 PM
  #51
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Originally Posted by rb23lb
when you say the backs are the same height as OEM...
well, they ARE oem still right, you didn't ever pull them off?!?
My daughters friends pulled them off. The after markets sit the same as OEM ones
Old 08-06-2008, 02:17 PM
  #52
aprince2die4's Avatar
08-C350 black/black
cool, got the same ones, but shipped for $8 cheaper here from US seller...
hope they are the same ones you got... they look exactly the same and the seller has great feedback
http://cgi.ebay.com/ebaymotors/ws/eB...m=250276008738
hey rb they are exactly the same and comes in the same box...mine also didnt have the caps on them when they arrived...u just unpeel the back of the cap and stick it on the door pin...i also have the three star pins...i had three caps pop on nicely but 1 didnt fit right...ill worry about that when i have to put the back ones on...
Old 08-06-2008, 02:22 PM
  #53
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
so the front carbon fiber pins close flush like the picture shows, but the rear, according to the above post, do not sit flush, even when you put on the new carbon fiber pins???
Old 08-06-2008, 02:24 PM
  #54
rb23lb's Avatar
wait... unpeel the cap?? Is the cap the part that has the mercedes star on it??? you are saying that this a separate piece from the carbon fiber stem?
what do you mean "unpeel"? Is it a sticker that you put on top of the cap?
Old 08-06-2008, 02:27 PM
  #55
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Yes, it's separate piece. I guess this way they could just give you the AMG caps if you prefer it over the star. And it's not just a sticker. It's etched and painted plastic.
Old 08-06-2008, 02:40 PM
  #56
08-C350 black/black
yes sorry they are not stickers but etched plastic that u stick on the pins...and they do not sit totally flush like in the pictures on ebay but only stick out slightly.. not enough to bother you if u sit ur arm on the window
Old 08-07-2008, 08:28 AM
  #57
RickP330's Avatar
2014 Mercedes C250 Coupe, 1998 SL 600 sport
Hey, Is there a better solution for the back pins? You guys didn't use them or had to modify them to get them to fit?
RickP
Old 08-07-2008, 12:19 PM
  #58
Azn_C300's Avatar
I haven't put them on yet.
Old 08-07-2008, 04:12 PM
  #59
rb23lb's Avatar
cant wait for my carbon ones to come on in... they look super clean on the pics posted! cant look any cleaner with the charcoal black interior...
perfect match
Old 08-11-2008, 12:35 AM
  #60
rb23lb's Avatar
got these from ebay...they slightly stick out when locked but you can hardly feel it if you like to lay ur arm on the window
man thopse stickers you put on are kinda cheap... just got mine today and you have to be really careful or else they bend or look shatty
Old 08-18-2008, 10:43 PM
  #61
who8888's Avatar
15 E350 4Matic
What do you guys think of this sets of door pin? I got got them today and swap out the front set. They feel really solid and sit almost flush.
Attached Thumbnails Door lock pins-AGAIN-dsc01759.jpg   Door lock pins-AGAIN-dsc01761.jpg   Door lock pins-AGAIN-dsc01762.jpg   Door lock pins-AGAIN-dsc01766.jpg
Old 08-18-2008, 11:05 PM
  #62
Ron Jr's Avatar
Looks nice Who.
Old 08-19-2008, 04:32 AM
  #63
AkaSigFreak's Avatar
E350 Sport/ML350RWD
Looks nice
Old 10-03-2008, 10:27 AM
  #64
nguyenmd350slk's Avatar
05-350slk and 08-c350
Exclamation
Originally Posted by AkaSigFreak
Just finished the rear pins. Went to the dealership the other day and left them fix them one more time. The new assembly was much better than the originals. They must have addressed the issue. I had to pull hard to remove them and when they came off- they were not cracked. I still wanted to change them.
Why don't we just cut the excess length (portion that stick out) of the pins when the rear doors are locked? Can I just do this? So when it locked it sit flushed with the panel? Thanks.
Old 10-03-2008, 11:07 AM
  #65
Ron Jr's Avatar
I cut about 1/4 inch from the bottom of mine and drilled it out to within 1/16 inch (estimate) I don't want to risk cutting any more off.
Old 10-03-2008, 02:14 PM
  #66
I meant cutting from the top when doors are locked. Then maybe put over a chrome cover if needed. Not cutting from the bottom. Thanks.
Old 10-03-2008, 03:54 PM
  #67
Ron Jr's Avatar
Now it's my turn I dought that would work as most of the pins that I have seen have decorative rings along the top. I'll take some pics of mine this weekend I may be able to cut a little more off. To clarify I think the bottom of the pin is down as far as it could go but there is still a bit of space in the pin to push it further down.
Old 10-03-2008, 04:00 PM
  #68
who8888's Avatar
15 E350 4Matic
Why would you even bother cutting it if you are going to cover it up? Why not just cover it up and save some work?
Old 10-03-2008, 04:18 PM
  #69
Ron Jr's Avatar
Who I don't think we are talking about the same thing. I am talking about the metal pin covers that replace the stock plastic ones. In the front they unscrew from the cable and the new ones just screw right on. The back doors though are held onto the cable by a ball joint so they cannot be screwed on. Some forum members have glued them on one I believe took his rear door apart and crimped the modified cover onto the cable. I went for a pressure fit method as this is what I am familiar with from the watch world.
Here is a E-bay auction for the pin covers that I have.
http://cgi.ebay.com/ebaymotors/Merce...mZ170249863421
Old 10-03-2008, 04:24 PM
  #70
who8888's Avatar
15 E350 4Matic
Got it! Though it was the pins.
Old 10-03-2008, 04:47 PM
  #71
Exclamation
ok, let me try to clear what i meant here. On the rear doors, thos lock and unlock pin stick out like the sore thumb even when the doors are in the lock position. Because of this the occupants in the rear tend to pull it up while sitting in the back, and will cause the fall out...My question is that " can I cut this down so it won't stick out so much when the rear doors are locked?".
Thanks.
Old 10-03-2008, 05:38 PM
  #72
white46's Avatar
08 C300
Thanks.
i was thinking the same thing. i don't see why not either.
Old 10-07-2008, 02:18 PM
  #73
Chaz00Blue's Avatar
2008 C-350 Palladium Silver and MM.
I was thinking about the Brabus ones too, but I saw some brushed aluminum ones for a CLK, but I'm not sure that they would fit. What do you guys think?
Old 10-07-2008, 02:40 PM
  #74
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
How much shorter are those than the stock plastic pins? I like the look and think it would be a simple clean looking add for a black interior with the aluminum trim.
Old 10-07-2008, 02:45 PM
  #75
Chaz00Blue's Avatar
I'm not sure, but they look like the same size as the Brabus ones. I thought they looked good too and they are $15 for a pair.
Quick Reply: Door lock pins-AGAIN
