Waxed car and now black plastic peice under rear bumber
Old Apr 12, 2009 | 08:41 PM
evanswan's Avatar
2010 E350 SP / Honda Crosstour / prior vehicles - C32 modded / C300 modded / Lincoln LS modded
I waxed the car and got wax on the plastic part under the bumber in the rear and it left white marks like it took the color off the plastic. I used plexus to polish and that didn't work. I tried armoral and that didn't work. any thoughts.
Old Apr 12, 2009 | 08:48 PM
len56's Avatar
C350
pics?
Old Apr 12, 2009 | 09:03 PM
ptronus31's Avatar
2008 C300
rubbing alcohol or citrus adhesive remover, then use something like armorall.
Old Apr 12, 2009 | 09:39 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
And we have a winner. The rubbing alcohol will take care of your problem.
Old Apr 13, 2009 | 12:52 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Use brake cleaner.
Old Apr 13, 2009 | 01:18 PM
joshg1001's Avatar
2017 E300
use a microfiber towel and water and just scrub it like crazy. it will come off. dont be fooled by the water on the micro towel, which will seemingly have removed it. you still need to scrub like crazy
Old Apr 13, 2009 | 10:34 PM
yooker's Avatar
a durr
Peanut butter
Old Apr 13, 2009 | 11:57 PM
Savage c-300's Avatar
C300 Sport, MM, P1
same thing happened to me. i used a plastic cleaner and that worked like a charm
Old Jun 29, 2009 | 02:35 AM
gmako74's Avatar
2008 C350 Palladium Silver
The best wax i've used is turtle wax ice, you can actually put it on black rubber and plastic trim...
Old Jun 29, 2009 | 08:22 AM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
The amount of crap in this post is unbelieveable....
...You first need to remove the wax. Using polish or anything like brake cleaner is a bad idea - polish will remove the surface texture and leave shiny spots and brake cleaner may actually melt the bumper.
Dishwashing soap or alcohol should take the wax right off. You can then use a protectant like Aerospace 303 to protect the surface and give it a rich color.
Most detailers frown on using ArmorAll as it damages the surface over time and leaves a greasy, high shine residue.
Unfortunately, the OP may have damaged his bumper already by using polish. He can try a product made specifically for restoring the black color such as "back to black" found in most auto parts stores.
Old Jun 29, 2009 | 08:40 AM
Glyn M Ruck's Avatar
Super Moderator
Listen to this wise advice! - Alcohol will take it off & don't rub like mad on anything!!
Old Jun 29, 2009 | 10:53 AM
iapboy's Avatar
C200
I have done this before... waxing the car with NXT and got it on the black part of the bumper.
Its was on there for a month before i decided to clean it.
i used Meguiar's Gold class trim detailer.
The wax came right off. Worked really well.
Old Jun 29, 2009 | 11:47 AM
AF330i's Avatar
A few different ones
Originally Posted by yooker
Peanut butter
I would recommend Peanut butter as well ... It sounds crazy and no it is not a joke and it works very easily ... you will be surprised, just put some on your finger and rub the area gently and you will see it comes off.
