2009 Mercedes-Benz C300 4MATIC Sport (LOANER)
My uncle received a white 2009 Mercedes-Benz C300 4MATIC Sport for a loaner because he had to drop off his 2008 Mercedes-Benz C300 4MATIC Luxury for some service that needs to be done.
I have a 2008 Mercedes-Benz C300 4MATIC Sport. I test drove the loaner and wow, it was MUCH quicker than mine!
I read the specs between them and nothing changed! Why is mine slower (as in pick up) than the loaner?
I took my car awhile ago to the dealership before I drove the loaner, telling them my car's acceleration lags and they said all softwares are updated and they don't find any issues with it.
I saw a forum, regarding the DIY Throttle Reset. What do you guys recommend? Should I try doing that? I have been babying my car as in, not pushing the gas pedal all the way down.
Please help!
there is a walk-thru if you search...
it worked for mine.
edit: here you go... i deceided to search as i need to do this again after my last service.
from the w204 secrets thread:
10) Steps to Reset the TCU. Resetting the TCU will reset transmission to factory shift points and the car will 'relearn' your driving style.
(1.) Turn the ignition key to the on (not start) position.
(2.) Press the gas pedal to the floor and hold for five seconds.
(3.) Turn the key to the "off" position (don't remove the key), then release the gas pedal.
(4.) Wait at least two minutes for TCU to reset.
remove the on/off button, insert your key and turn to the right, just before the engine starts, once completed turn key back, remove key, and insert on/off button back
Done...
I remember reading somewhere that there is a new software for either ECU or TCU that's suppose to fix the lag problem..
I am taking my car to dealer on Friday and that's one of the thing on my list..
There are 4 positions for the ignition switch (0, 1, 2 and start engine)
I assume the correct step is to put the key in then turn to 2 position then hit the gas padel for 5 seconds right?
How about after hitting gas padel for 5 seconds, do you turn to 1 then release the gas or do you turn all the way to 0??
Please help!
