HELP..side marker not lighting up
Old 06-06-2009, 12:29 AM
albchao's Avatar
2008 C300 Sport
I decided to try the resistor trick with LED today..unfortunately it didn't work and the LED wouldn't light up at all. So I gave up and put the original bulb back in..but it doesn't light up at all. Anyone know what's wrong?? The wires seem to all be fine..
Old 06-06-2009, 12:49 AM
GateKeeper's Avatar
GLA45 AMG, GLC43 AMG
check the fuse ?
just a guess, I don't know if they are on a separate fuse or not, I have not looked this up
Old 06-06-2009, 01:03 AM
albchao's Avatar
2008 C300 Sport
Hmm..I don't know about the fuse. Do you think I should ask the dealership? Or is it possible my warranty will get voided because I messed with the wiring? I've read that in another thread once..
Old 06-06-2009, 01:06 AM
GHAZAN's Avatar
MBUSA
Do you have pictures of the wire and your 'resistor trick'?
Maybe a voltmeter to see if there is still current? Check the manual for fuse diagram also...
Old 06-06-2009, 02:41 AM
albchao's Avatar
2008 C300 Sport
The 'resistor trick' I read about on got_thang's DIY on LED conversion. I will take pictures tomorrow and post them.
Old 06-06-2009, 02:43 AM
albchao's Avatar
2008 C300 Sport
Thanks for the ideas, I'll see if I can get my hands on a voltmeter.
Old 06-06-2009, 03:18 AM
aranu's Avatar
C230 2009 , E320 1996, C230 Coupe 2002
True the bulb the other way around? the bulb doesn't flick on unless its inserted the proper charges.
Old 06-06-2009, 03:32 AM
albchao's Avatar
2008 C300 Sport
I've tried that too..put the bulb in both ways multiple times. I've tried it with different bulbs so it's not because the bulb is burnt out or anything. I don't know, I'm stumped as of now.
Old 06-06-2009, 05:31 PM
albchao's Avatar
2008 C300 Sport
So I just went downstairs to take some pictures... then out of no where the side marker starts lighting up again. It's weird, cause then the other side wouldn't light up, but after turning my engine off and on it lit up again. What a mystery.. but at least they both light up now! Thanks guys for the input!
Old 06-06-2009, 05:33 PM
PolePosition's Avatar
C350
Just curious, when it didn't light up did you get an error message on your display?
Old 06-06-2009, 06:37 PM
albchao's Avatar
2008 C300 Sport
When it didn't light up there was an error message displayed..as I guess the bulb wasn't sensed as being in place.
Old 06-11-2009, 07:16 PM
who8888's Avatar
15 E350 4Matic
It happened to me also. When you put in a LED and the car does not like it, it does not light back up the regular bulb until you turn off the car and then turn it back on. The first time it happened to me, I freak like you did...
Quick Reply: HELP..side marker not lighting up
