Retrofitting COMAND (MM) writeup.
Old Jul 14, 2009 | 03:58 AM
  #76
Diesel Benz's Avatar
Originally Posted by justthinking
vic viper, is it possible to upgrade the 5" display of audio 20 w/ the 7" display w/o change the HU??
also, check out this link..
http://www.mbusa.com/mercedes/#/vehi...Z&yr=2010&vc=C
there is a new command package listed which doesn't offer navigation..I thought audio 50 will have dvd base navi??
I don't see why one would prefer the 7" display with Audio 20 when it does not play DVDs. With UMI navigation a bigger display could make sense if it was properly used (unfortunately that does not appear to be the case like explained above).
Audio 50 APS would also use the smaller display.
Old Jul 14, 2009 | 07:49 PM
  #77
Nuru's Avatar
S350 BT 4MATIC
Well this Saturday, I am gonna try one more dealer to get my NAV data to IC display configured. Wish me luck! LOL!
Old Jul 19, 2009 | 06:18 AM
  #78
mrjsw's Avatar
W204
Ok , i finally get to the bottom of it for everyone who wants to fit a blower to a RHD vehicles. Below is the picture of the parts number A2048300808 for RHD. As you can see, this blower comes with addtional two components with a rigth angle tube and a bracket that will fit right next to the hard drive underneath the steering coloumn. No screw required, just snap it in. Bascially this is all we need plus the intake duct. Unfortunately i have bought the whole ducting set as per the EPC which is NOT required for RHD. The whole installation took me about 15mins..
This is where the air will come directly from the blower ie (MORE efficent for the LHD vehicle without the long ducting)
Old Jul 19, 2009 | 06:50 AM
  #79
vic viper's Avatar
S213
Interesting, I alwys thought that RHD cars would have the same ducting only mirrored.
looks like its alot easier to install a RHD fan system but find it a bit strange that the air isnt ducted upwards towards the HU fan air intake along its left side.
Old Jul 19, 2009 | 07:52 AM
  #80
mrjsw's Avatar
W204
Me too, i thought that it would be mirrored. In fact, i always thought my local dealer doesn't know what he is talking about until today i found that he is right. Well, things aren't alwasy black and white and straight forward.
Old Jul 19, 2009 | 11:53 AM
  #81
qwqwerertyty's Avatar
2009 C350
Originally Posted by mrjsw
mini turbo!
Old Aug 4, 2009 | 07:16 PM
  #82
originalino's Avatar
w204 220cdi
Hallo guys!
I just made an upgrade today from APS50 NAVI to COMAND APS NAVI system. I did not had to go to the MB Dealer for the new codes that are required the system is woking perfectly, maybe because it had already the APS50 NAVI system...I also did not installed the external blower... Do you think i will have problems in the future?
Thank for yor answers!
Old Aug 5, 2009 | 09:50 AM
  #83
mrjsw's Avatar
W204
Originally Posted by originalino
Hallo guys!
i woudn't risk it as it is a fair expensive gear. you will also notice a lot of error messages in the eng menu (high temp and ext blower error). more importantly it does get really hot even in winter. My external blower always runs at 37% even outside temp is 10degree.
Old Aug 5, 2009 | 04:52 PM
  #84
w204 220cdi
What about the recoding? Do you think its also necessary?
Old Sep 1, 2009 | 04:51 PM
  #85
w204maniac's Avatar
c200 kompressor
vic viper gave the part numbers of all we must use for comand retrofit.
why the external blower is not in the list?is it optional?
i have just ordered only the part numbers that vic mentioned .not the external blower.should i ?
Old Sep 1, 2009 | 08:17 PM
  #86
Which parts list are you referring to? This one did include the axial blower. Or which blower are you referring to?
https://mbworld.org/forums/3561910-post4.html
Old Sep 3, 2009 | 03:07 PM
  #87
w204maniac's Avatar
c200 kompressor
thanks.that is i have ordered.it is called axial fan in the list(not blower) and i was thinking that it was different part.
Old Sep 3, 2009 | 06:28 PM
  #88
Luisin's Avatar
W204 C180K AMG
I have all parts of Comand APS. Next week I think I will Install all compontents.
I have a question, for the EU cars? its the same code for a DVD Changer? must I replace it? I have Audio 20 in my car
ANd another question, did you fit the axial blower for the RHD cars in a LHD car? It works nicely? Because I think that the blower needs fresh air that comes in from the steering column space, and If we try to install this blower into the right (where the RHD cars have the steering column) its possible than it will not work correctly
Old Sep 3, 2009 | 08:03 PM
  #89
tommy1752003's Avatar
MB C230 4Matic
would it be a direct swap just to put in the 7 inch screen
or would it need more than that
i have the 5 inch audio 20 i think
5 inch screen and single cd/mp3 player
Old Sep 26, 2009 | 05:40 AM
  #90
Mike_2011's Avatar
2009 C300 Sport
Here I have installed the retrofit cable harness (blue arrow) , the two black and white cables are interior CAN cables to be connected in the CAN hub (yellow arrow) connect them anywhere in the hub, the red arrow is pointing to the ground point for the harness, the other end is routed to the forward SAM module,
The SAM module must be removed by loosening four torx screws, then pull the entire SAM unit up, then locate a large 14-pin pink connector, remove and disconnect the red/blue line placed in cavity 6, replace with retrofit harness wire, assemble in reverse order.
What is this step for?
Old Sep 26, 2009 | 07:41 AM
  #91
vic viper's Avatar
S213
What do you mean?, it describes how to connect the cable harness.
Old Sep 26, 2009 | 12:25 PM
  #92
Nuru's Avatar
S350 BT 4MATIC
agree, that is why I did it too. The COMAND does get hot
Old Sep 26, 2009 | 12:28 PM
  #93
Nuru's Avatar
S350 BT 4MATIC
It is not a direct swap, the 5" display uses a power harness that employs two connectors, the 7" display employs a single connector. If you intent to use your original harness, you will need to perform some surgery on the existing power harness to make it compatible with the 7" display. If you are going to use the entire retrofit harness then you are ok, becasue it is configured for the 7"display.
Old Sep 26, 2009 | 12:34 PM
  #94
Nuru's Avatar
S350 BT 4MATIC
I have seen pics of Audio20 units using the 7" display and it doesnt look good, the resolutions dont add upp and it looks pretty strange.
Regarding the Comand system w/o navigation I bet that they are using a different HU without the GPS and voice control parts.
Yes they are, here is a visual look at the Audio 20 (Left) vs COMAND w/NAV (Right). This is a rear view vs rear view look.
Attached Thumbnails Retrofitting COMAND (MM) writeup.-rear_non-nav.jpg   Retrofitting COMAND (MM) writeup.-204-870-34-96-comand.jpg
Old Sep 26, 2009 | 01:19 PM
  #95
Nuru's Avatar
S350 BT 4MATIC
also check out this thread.
http://www.benzworld.org/forums/audi...4-c-class.html
Pages 10 - 19 have a good deal of information for any do it your selfers. It is good background information and would be a good read prior to using Vic's procedures, which are excellent!
  #96
Nuru's Avatar
S350 BT 4MATIC
RHD's sure got it easy on this install!
Old Sep 27, 2009 | 09:17 PM
  #97
Mike_2011's Avatar
2009 C300 Sport
Alright just to be sure am almost certain I am buying the Command via Ebay but I don't have to add any cables right? all cables that were used for the old HU will work with the new monitor and HU?
Sorry for asking so much
Old Sep 27, 2009 | 09:25 PM
  #98
mirage15's Avatar
c300 4matic
You do not have to use a new wiring harness... it is sometime easier... Nuru (I believe) posted a wiring diagram of what you need to cut and splice on the Audio20 harness to make it work with the Nav COMAND.
Old Sep 28, 2009 | 02:08 AM
  #99
vic viper's Avatar
S213
You do not have to use a new harness, but it simplifies things, and the two additional harnesses arnt that expensive.
Old Sep 30, 2009 | 07:26 PM
  #100
Nuru's Avatar
S350 BT 4MATIC
Actually, it is manipulating the display power harness, so the 7" display will work on the Non-Nav harness. The Comand HU main connector will need to have add the power harness for the Axial Blower added to it, from the retorfit harness.
Vic is correct the retrofit harness is not expensive. Neither is the display data cable for the 7"monitor, you would need both.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
