C63 Quad Exhaust
Old Sep 2, 2009 | 09:49 PM
Asianguy's Avatar
C300 Sports 4-Matic
C63 Quad Exhaust
Would it be easier if you can just buy the C63 Quad OE mufflers from the dealer and install it to either the C300/C350 than do modified the existing single muffler to make it to a Quad?
I'm not sure how much it will cost, im sure it will be expensive or would it even fit?
Old Sep 2, 2009 | 10:31 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Easier to buy C63 quad exhaust. Cheaper to mod existing exhaust to quad.
Old Sep 2, 2009 | 11:53 PM
Derspeed's Avatar
X3 and 2012 C coming soon
The C63 mufflers also make the V6 sound terrible.
Old Sep 3, 2009 | 07:45 AM
Merc-IN-the-Dez's Avatar
2009 C350
exhaust blues............
Hello Fellas, I own a C350 (09) and understand about what goes on in yer heads, I had a chance to talk to some mechanics today at the dealership and they have done several mods to existing 350's w the '63 exhaust.
Basically they said that they recommend using the pipes and mufflers after the center muffler of the 350. this will give you a little more noise and better flow but will not make the car drone.
If you use the stock '63 assembly again the noise level will be increased much more, though it might sound nice in the beginning, for everyday driving it will be annoying.
I am considering using the '63 assembly after the 350 center muffler, they quoted me approx $3,000 for all the hardware including the amg quad tips installed in house. I bought a '63 diffuser already.
Unfortunately I have to go this way because installing another system will void my warranty
The file I uploaded is for a C63, again unfortunately, you have to get rid of the center muffler even if you pay for it.
I haven't done mine yet but maybe in two weeks I'll get around to it.
You will need the section with #240 and # 200 for the 350 conversion, they will make a cut behind the #240 section, I saw Vader's conversion and that was clean as well. This is just going a different route.
Old Sep 4, 2009 | 02:03 AM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
wait the warranty cn be voided??? what if i just use 2 extra oem c350 tips welded on like many have done with the new diffuser from the c63? this will still void the waranty cus some welding was done?
Old Sep 4, 2009 | 02:50 AM
2009 C350
warranty
Hello, no your warranty won't be voided if you just install the tips, as per my dealer, if I had installed a cat back exhaust then it will invalidate my warranty, each dealer is different, I suggest you check yours first, happy driving.........
Old Sep 4, 2009 | 11:36 AM
Azn_C300's Avatar
By law (in US), they'd have to prove that your mod caused the issue and as cat back systems are purely sound aesthetic, good luck to them proving that caused the failure.
Old Sep 4, 2009 | 12:20 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
$3000.00 is not worth it, my dealer quote me $1800.00 for the C63 exhaust system.
My $0.02
Old Sep 4, 2009 | 10:35 PM
Derspeed's Avatar
My dealership's warranty advisor told me that as long as the exhaust system does not impact the emissions control system or throw a CEL, it will not void the warranty. A resonator back system will have no effect on the emissions control system.
Old Sep 5, 2009 | 03:30 PM
2009 C350
Hey Tanktube, pm me your dealer's contact details if you can, thanks.
