Axxis Ceramic pads installed
No, gotta read it again... my receipt states the replacement in the rear...
1 week with OEM rear pad = 400 - 450 miles
1 week with new axxis rear brake pad = 400 miles
total = 2 weeks of driving
total = 800 - 850 miles
and also is there any squeaking with the axxis pads? (can't stand squeaky brakes)
And finally, did you get the revised pad? I am confused on the differences... one doesn't allow the metal clip to fit and the new 1 does? How do you know you got the new kind ?
i provided everything in the beginning of the thread like where to buy it, who makes it, and what was wrong with it.....but here u go again..http://www.axxisbrakes.com/wheretobuy.html
no squeaking with the new axxis pads....beside the minimal brake dust, braking performance increase a little bit... i only say that because i only change the rear and most of the brake is done in the front... so until then, i cannot give u a complete assessment of the whole brake performance...you would be very happy with these brake pads though...
yes, i got the "revised axxis rear brake pad"..... the axxis brake pads is suppose to come with a metal clip that is attached to the pad (look at the pic)....but just like any other new product, usually there is some sort of defect when it is new...(you would know you got the right one when the pads comes attached with the metal clip).... NO clip means defect!!!... other members have stated that they install them without the clip but personally, i would not advise anyone to install them without one...there are other issues that might occur if brakes are not installed properly with the right components...just my 2 cent!!! Although, i wasn't the one that posted this thread, i was one of the first one to get these pads (look at my receipt) and so i felt bad if i didn't say anything to better inform other members about the product...
oh, nice lighting on your car by the way...
But have to...100% totally agree and endorse Akebono !
Been running them on the 250 CDI since 2014 when I first discovered them.
Fantastic longevity on top of almost zero brake dust, zero squeal/noise. They have lower initial bite but comparable stopping to OEM with full force and no unnecessary/abnormal wear to the discs.
For best results I would also recommend new discs fitted in concert with new pads at the same time so that they can wear in together from new, because of the long life of these pads it works out well worth it.
I'm totally confident to use Akebono pads on any other car that they make them for
