C350 exhaust resonator removal?
Has anyone had their center resonator pulled out of their exhaust and replaced with a straight pipe? If you have heard of anyone doing this please let me know. Thanks
yes, we've had people do straight, H, and X pipe before.
its called an X-Pipe
Originally Posted by Azn_C300
(Post 4041658)
I wanted to find a clip of straight but was never able to. Straight pipes cost WAY less to do, but beacuse of no clips and everybody saying it'll sound bad I went with x as well.
I've heard straight pipe. Sounds too raspy.
I have a magnaflow x-pipe for sale. PM me
why does an x pipe change the sound? in what way?
Originally Posted by chubbs032
(Post 4041989)
Can a shop fab up an x pipe? Or is it better to just purchase an x pipe? Also, any idea on the difference in sound without the res?
Also, does anyone know what the pipe size is? 2.25" or 3"? Also, I see that Magnaflow makes two different options. One is 12" long, and the other is 9". Does anyone know what option is the better way to go? Here are the links:
http://www.magnaflow.com/02product/s...e=main&id=8708 http://www.magnaflow.com/02product/s...e=main&id=8703 http://www.autoanything.com/exhausts...A2672A0A0.aspx |
You can have a muffler shop fab you an x-pipe, but might not be the best in terms of performance or material quality. And you want 2.25" pipes.
(Post 4042883)
2.5" will fit as well, they won't have to stretch open up the ends like they would with 2.25" pipe. Also AFAIK your going to need extension pipes anyways bc these magnaflow x-pipes are shorter (12") than the resonator which is like ~20" or something
Is it better to order the x pipe in a 2.5 or 2.25?
Just FYI for anyone interested in doing the resonator delete to X Pipe mod. If you YouTube "C350 X Pipe" you will find a video from ExhaustDepot.com showing how they made a custom fit, bolt on x pipe for a C350. I emailed them and they said to make a custom fit all bolt on X pipe runs $175. Not too bad, considering its a bolt on and custom fit so there are no extra pieces of pipe needed and it is the correct length. Not to mention its a flanged end on the cat side so there is no cutting into the cats.
I am ordering mine today. I will post pics after its installed, in the mean time check out the video. Pretty impressive quality |
too affraid
Originally Posted by CureCar
(Post 4041535)
What kind of mod can be done to give a better, improved sound and not void warranty?
This is really a very simple and common mod so don't be afraid to try it. It will not void your warranty as anything cat back is fair game. This has all been covered once and I'm sure will be covered again. Get 2.25 openings, and any halfway decent muffler shop can take care of this modification for you. If they look at you confused when you tell them to replace your resonator with an x-pipe, find a different shop instead of explaining it to them. Also when they do cut your resonator, make sure you keep it so if you later want, you can go back to stock without having to buy a new resonator.
Originally Posted by patrickkc
(Post 4041854)
Originally Posted by Robbio204
(Post 4042031)
It takes the bit of growl we have stock and amplifies it a couple times. Idle sounds pretty much the same, 1500-4000 is maybe twice as throaty(my favorite) and around 4500 it can get pretty loud. You also get a nice burbly, poppy idle on cold starts...sounds pretty mean!
(Post 4048663)
Originally Posted by C300Sport
(Post 4049032)
I tried it and it was indeed pretty cheap...I think $55. The likely reason you can't find any clips is because anyone who has ever tried it only leaves it like that long enough to get an appointment to change it. Sounds like crap!
The stock resonator is essentially a big x-pipe but it has built in baffling in the walls to reduce sound waves. It takes the bit of growl we have stock and amplifies it a couple times. Idle sounds pretty much the same, 1500-4000 is maybe twice as throaty(my favorite) and around 4500 it can get pretty loud. You also get a nice burbly, poppy idle on cold starts...sounds pretty mean! The x-pipe is the cheapest easiest way. Anyhing aft of the cats is fair game and won't void the warranty. |
Originally Posted by Krytech
(Post 4050633)
So did you leave your resonator in place and add an x-pipe? What are most people doing, replacing the resonator with an x-pipe or adding an x-pipe?
when addin x pipes, does this increase power to the car?
Originally Posted by Red_Demon08
(Post 4057191)
(Post 4049032)
