Problem with install LED tail light W204
1 Attachment(s)
today i buy from eBay a new LED tail light for my W204, but i install it easy and when i turn on the light the up lights doesn't turn on!!!!!but other light it work, i call to supplier and he said you must reset you computer and then it is turn on, i go to Benz work shop and they are reset my computer, but this isn't work?!?!?please somebody help to fix this problem.
idk but i like those lights.. ??
Check your fuses? The diagram I believe is in the trunk near the spare?
Edit: Also, it could be different lighting pattern from OEM and only turn on when the brake is applied? |
No work
Originally Posted by shemirani
(Post 4120238)
i had no idea there was an aftermarket led tail light?
Originally Posted by ISPEEDM3
(Post 4121103)
http://www.google.com/products?q=eba...ed=0CC8QrQQwAA |
it could just be that the bottom light light up when you hit the brakes. Turn your fog lights on n pull the switch all the way out. go to the back of the car and see if the light is turned on. that could be the rear fog light.
Originally Posted by RLE
(Post 4120985)
There is no software reset for LED rear lights so that advice is wrong. Substituting LEDs for a conventional bulb in the taillight position probably triggered the lamp out module to turn on an alternate bulb since the low current flow of the LEDs looks like a failed bulb to it.
but why other lights is work? the barke and all of them is work just up light is not work? |
Originally Posted by Ants09c-class
(Post 4121373)
Trying this but not work ,just the right light up is turn on!!! |
when I remove the LED Socket from lamp supporter and install the original lamp it is work and it mean the electricity is flow, but when put back it to LED socket this in not turn on(just on up light)
contact the ebay seller and let him now. The solder point in the LED circuit board must have been bad on that light. Ask to replace it, or you can fix it yourself if you have a solder. Its not the car if the right one works.
Originally Posted by jctevere
(Post 4121643)
and i forgot, the message in car computer is: REAR RIGHT SIDE MARKER LAMP, maybe this is help for find problem
(Post 4121892)
Just so we can understand your exact problem, it's the upper parking lights that are the problem? Do the lower brake lights work ok? Do the turn signals work ok? |
3 Attachment(s)
Originally Posted by Krytech
(Post 4122178)
Just shooting in the dark here, but maybe you need to install a resistor? If I recall correctly, you need something like a 6ohm 50W load resistor to make the error message go away and maybe then the computer will behave differently? :nix:
Just so we can understand your exact problem, it's the upper parking lights that are the problem? Do the lower brake lights work ok? Do the turn signals work ok? please lock at pic maybe help to find problem Attachment 185186 Attachment 185187 when brake: Attachment 185188 see all of the lights is ok but the up light is off,oh god |
today the supplier said is :
THE LIGHTS IS DESING LIKE W221,and the up light is for fog lamp................. yes he is right, when rear fog lamps is turn on, 1 side is turn on(Up light)"this is right" but I Thought it must like original lamp, I mean up+Dowm is turn on, and now the design of light like S class and it mean the LED tail light is work true |
ive heard benz and LED's dont make good company
so.. how do you make the upper ones come on? by turning on fog lights?
yes, up lights just for fog lights(in LED Tail light), LEFT up for fog and right up side is off for always, the rear fog lights is only 1 side
overall are you happy with these lights? Were these an ebay purchase? I like em, do you have a link?
I have full LED tail's as well. Check out my thread on them. Mine don't have the upper part LED..which I like. And NO error messages.
Originally Posted by blue00r6
(Post 4125575)
yes this is very nice and different and very good quality, follow this link on Ebay: http://motors.shop.ebay.com/i.html?_...=&_trksid=m270 on ALIEXPRESS: http://www.aliexpress.com/wholesale?...ht+led&CatId=0 |
ABOUT THE COMPUTER ERROR MESSAGE(REAR RIGHT SIDE MARKER LAMP)on LED tail light:
Today I install the resistor for right tail light and the error message is clear |
also the rear fog lights are leds???
PROBLEM WITH LED TAILS W204
HELLO I HAVE THE SAME PROBLEM OF SHEMIRANI.
I INSTALLED THE LED TAILS ON MY W204 AND THE LIGHT UP DOESN'T WORK. HAVE YOU FIND A SOLUTION TO IT? |
