AZN Optics 5W5 Canbus LEDs
Old Nov 21, 2010 | 02:53 AM
  #251
AZN Optics's Avatar
SPONSOR/MBworld Guru
Originally Posted by mkng
mike,
'just sent payment(via paypal) for 3 pairs of 5000k whites
Originally Posted by C300 EPM
sent out another payment for my friend for 2 sets 8000k LEDs. Received the LEDs from previous purchase. Can't wait to get it install
Originally Posted by Travisau
Payment sent
Will ship out first thing monday morning.
Old Nov 21, 2010 | 04:47 PM
  #252
jctevere's Avatar
2012 C250 Coupe
Mike, have you had any progress on the other LED bulbs you were trying to source for the tail lights?
I would be interested in 6000k reverse LED lights for the tails, and red LED upper light for the tail lights (as I bought after market tail light that has the bottom light and turn signal LED, but the top still uses my old halogen bulb.
Old Nov 22, 2010 | 04:53 AM
  #253
Renesys's Avatar
C 350 Cdi 4M
Payment sent
Hi Mike!
Just sent the Pay pal payment for 3 sets of 5000k anfd transport rate for international.Tell me when u are going to ship the leds, hope there won,t be any problems,because this is the first time i buy from US.
Thanks!
Old Nov 22, 2010 | 12:58 PM
  #254
AZN Optics's Avatar
All weekend orders have just been shipped out. Thanks everyone!
I've decided not to do reverse light and tail light LEDs as there just doesn't seem to be much of a market for them. Also, the design I have for turn tail light wasn't as bright as regular bulb unfortunately and alternative design to make it brighter would make it pretty pricey. I might revisit it at a later time, but for now turn signals should be here hopefully this week with my next shipment and then I'll be tackling festoons.
Originally Posted by Renesys
Hi Mike!
Thanks!
Will be shipped out tomorrow morning
Old Nov 22, 2010 | 06:10 PM
  #255
adr14n's Avatar
13' CLS63 10' SLS
Have you shipped mine?
Old Nov 22, 2010 | 07:14 PM
  #256
AZN Optics's Avatar
Old Nov 22, 2010 | 07:53 PM
  #257
jaeguyoon's Avatar
08 c350
you're service is just amazing. Just received mine. Thanks!
Old Nov 23, 2010 | 11:13 AM
  #258
Skinny's Avatar
C300 4 MATIC (2013)
Burned bulb
One of my eyelid LED's I purchased from you earlier this summer Just burned up.
I thought this was not an issue with these LEDS!
Old Nov 23, 2010 | 11:33 AM
  #259
Skinny's Avatar
C300 4 MATIC (2013)
Thumbs up
Wow what an amazing service! AZN just replied to my concern within 5 minutes!
It may have be an improper install on my account or a simple fault.
Sending a replacement!
Thanks!!
Old Nov 23, 2010 | 11:45 AM
  #260
AZN Optics's Avatar
Thanks!!
Yeah, 99% of the time, when there's component seperation, you have solder failure and that'd due to over insertion where the voltage plate touches the resistor or other components, cause that's the only way it could get hot enough to the point where the solder melts. I've talked to several other LED manufacturers and this is a pretty common install issue with open circuitry LEDs. Just gotta be careful when you plug it in, as soon as you feel resistance, that's the first resistor touching the voltage plate. Pull it out at that point to give you some buffer space. Then when you go to plug the connector back into the housing, grip the connector and LED 50/50 as some accidently push the LED back in too far again as they ferret out the hole in the housing.
I was going to get the manufacturer to extend the length of the LED to help minimize the potential for over insertion, but as some pointed out here, then they wouldn't be able to fit these in the rear plate or sidemarkers as they just barely fit perfectly in there, so opted against.
Old Nov 29, 2010 | 11:53 AM
  #261
AZN Optics's Avatar
Good morning everyone. Just got back from post office and all weekend orders have now been shipped out. Thanks for the orders!
Old Nov 29, 2010 | 01:09 PM
  #262
-Reno-'s Avatar
got weird problem that i noticed yesterday
when i open or close the car after the light goes off, one led stay lite, goes on and off for about 3 times and only then goes off completely
anyone knows what wrong?
no big deal but kinda weird
Old Nov 29, 2010 | 02:24 PM
  #263
jctevere's Avatar
2012 C250 Coupe
@ Reno, my guess is that maybe a resistor is acting up or faulty. That's about all I can think of. Make sure the connection is good and that nothing is physically wrong or bad with the LED. I am sure mike is working on an answer for you as I type this.
@ AZN You said that you dropped the reverse, brake light and tail turn signal LED, but that the next turn signal LED should be on its way soon, are you referring to the front turn signals?
Also, what is the festoon bulb, is that the interior rear seat dome bulb? How do LEDs fare in the interior, I just kept the polarg M4 because they did the trick; I am not sure if I want super bright LED in the interior. Does it cover the inside well or is it just concentrated bright light and dark areas like the leds under the mirror? Also, do the LEDs maintain the dimming to off function or is it just immediate full on and off?
Thanks for all your help and support, I greatly appreciate it!
Old Nov 29, 2010 | 03:53 PM
  #264
AZN Optics's Avatar
Try switching the LED and see if the issue follows the LED or if it stays with that socket. If it follows the LED, might be an issue with the LED and I'll warranty it. If it stays with that socket, then you probably have a wiring issue where that socket isn't completely powering down when it should. Remember, it takes much less voltage to light up these LEDs compared to normal bulbs.
I nixed the idea of reverse and brake lights, but turn signals are still a go. on 204s, the rear turn signal is different than the front turn signal. I've got the rear ones worked out and ready to go, but ran into some issue with the front. Did some debugging and worked out some kinks with my engineer. My new test set for the fronts were actually just delivered today so I'll be testing them out. If all goes well, I'll be hosting a group buy for turn signals. I'll offer red, white, and amber for the group buy and the two colors that sell the most will be the two colors I'll be offering moving forward.
Regarding LED interiors, the Festoon bulb I'll be working on will work for your rear dome light, but was more marketing it towards other MB classes who have festoon plate lights. I had interior LEDs on the front and rear dome, but ended up taking them out as the light was a bit too harsh in dead of night for me. However, I think my LED lights work great for the front foot well as it provides a nice ambient lighting and looks pretty slick.
Old Nov 29, 2010 | 04:48 PM
  #265
C300S 6MT's Avatar
C300, 330i, MDX
Michael,
Can you bring some front-yellow and rear-red turn signal LED's @ AUTOCON?
Thanks/ Joel
Old Nov 29, 2010 | 06:31 PM
  #266
AZN Optics's Avatar
Originally Posted by C300S 6MT
Michael,
Thanks/ Joel
I won't have those ready by autocon as I'll be ordering them after the group buy. I already sold off my original test set for the rears, but if the fronts work out well, I'll be sporting the white fronts at autocon. Hit me up at the show if you want to see em. I'll be either running around with the Europrojektz crew or at the DPE booth. Just ask anyone there and they can point me out. The MyMB guys you're going with can probably track me down as well.
Old Dec 1, 2010 | 11:52 PM
  #267
mango626's Avatar
2008 C 350
Payment sent
Hi,
Just sent Pay Pal payment last night for 3 sets of 5000K.
Thank You!
Old Dec 2, 2010 | 11:50 AM
  #268
AZN Optics's Avatar
Originally Posted by mango626
Hi,
Thank You!
Got it, will ship out tomorrow morning
Old Dec 2, 2010 | 02:23 PM
  #269
-Reno-'s Avatar
[IMG][/IMG]
Just a pic to share
I got the 8000K ones if anyone wondering
love it
Old Dec 4, 2010 | 05:33 AM
  #270
gonzo7117's Avatar
C300
Just got my LEDs...thanks
i'll install them in an hour
Old Dec 6, 2010 | 09:09 AM
  #271
snarlingchicken's Avatar
2009 C350
So......Michael. Hate to keep asking you, but what are the chances that I can buy myself a pair of LED turn signals for Christmas this year? How's the test set looking?
Old Dec 6, 2010 | 01:27 PM
  #272
AZN Optics's Avatar
I got my new test fronts and not too happy with them. Basically the front turn signal, even when off, bleeds some voltage to the unit still which causes the LED to very slightly light up when off. To get around this, they have a separate flasher unit to install which will cut off voltage and regulate the blinking. I want these to be as plug and play as possible and having to force you guys to do any sort of rewiring that weekend DIYers can't do is unacceptable. Right now, I'm thinking of just opening up the group buy for the rears and keep working on the fronts.
Old Dec 6, 2010 | 08:47 PM
  #273
2009 C350
Sorry to hear that :/ I guess I'll just buy myself some chrome paint for now then. Thanks for all the effort Michael.
Old Dec 7, 2010 | 02:36 AM
  #274
Toast's Avatar
2010 C300
Payment just sent for 2 pairs of 5000k, thanks!
Old Dec 8, 2010 | 05:09 AM
  #275
Renesys's Avatar
C 350 Cdi 4M
Hey Mike! I just pick up the leds, they arrived in safe conditions.I will install them today.
Thanks man.
