2010 C300 - How to reset service message
Hi,
Can someone tell me how to resent the ASSYST PLUS message regarding Service A? I have tried the procedure for earlier model years, but apparently the system was changed in 2010 because the displays are different and earlier instructions don't work. Thank you. |
Here's the MB reset instruction
1 Attachment(s)
Note: Make sure that you close the driver's door behind you BEFORE you get started!
I found that if I reset it before it was due all went well. When I waited until it was overdue I had to have it reset by the dealer.
Originally Posted by MaineSailor
(Post 4554632)
Thanks,this worked perfect
Originally Posted by mi first benz
(Post 4861873)
I did all the steps, but at the end I got the next mesage:
it has not been possible to carry out the full maintenance |
Try to use push the "START" button twice
Originally Posted by altata
(Post 7751947)
it has not been possible to carry out the full maintenance Here is what I did this week for my C300 reset: The procedure in the PDF file sometimes works but this week I tried it failed. Instead to do the step 1 listed in the PDF file (insert key and turn to position 1), I push the keyless start button twice without foot on the break. Then follow step 2 to the end. |
I dont
Originally Posted by xkcmdmb
(Post 7752195)
Here is what I did this week for my C300 reset: The procedure in the PDF file sometimes works but this week I tried it failed. Instead to do the step 1 listed in the PDF file (insert key and turn to position 1), I push the keyless start button twice without foot on the break. Then follow step 2 to the end. I dont have the keyless start button. |
