AZNOptics.com Storefront - W204
Old Jun 26, 2015 | 05:23 PM
  #476
AZN Optics's Avatar
SPONSOR/MBworld Guru
Originally Posted by will042082
@AZN
Hey man what's the chance I can swap my 4-5 sets of the old versions for 3 sets of the new V5s? I'm so tired of plugging and unplugging due to blinking etc. We replaced em once and they work well for a period of time but just don't hold up. If the new V5's are that much better my sanity would be saved!
Send me an email at aznoptics@gmail.com with your name and address so I can look up your record and see what I can do.
Old Jun 26, 2015 | 05:36 PM
  #477
will042082's Avatar
2008 c300 4matic Sport
Done.
Old Jun 30, 2015 | 09:13 AM
  #478
will042082's Avatar
@AZN
Received my replacement V5 bulbs and got em in yesterday. Looking good so far but with these it takes time. I did notice that it was significantly harder to get the LEDs in the connection. I was almost worried I was going to break them due to the pressure required. Just an FYI. The again!
Old Jun 30, 2015 | 12:06 PM
  #479
AZN Optics's Avatar
It is a tighter fit due to the resistor at the base, but as long as you have it lined up, it should fit in with firm pressure. You won't break anything.
Old Jul 23, 2015 | 01:27 AM
  #480
AZN Optics's Avatar
AZN Optics is now offering next generation Morimoto XB35 HID conversion kits. Available for order on our site www.aznoptics.com or PM us for more details.
Old Sep 2, 2015 | 01:37 AM
  #481
AZN Optics's Avatar
bump
Old Sep 2, 2015 | 08:18 AM
  #482
Doa's Avatar
Doa
W205
can you give us some info?
i see a lot of cables and stuff
Old Sep 2, 2015 | 11:46 AM
  #483
AZN Optics's Avatar
On the HID system? Sure.
Elite HID Systems:The aftermarket's best HID system. The best ballasts, the best bulbs, and the best harness culminate to bring your aging headlights into the modern era!
HID Ballasts: The all new XB ballasts feature relocated igniters like OEM units, putting them far closer to the HID bulb. The lack of high voltage transmitted through wiring drastically reduces EMI/RFI (radio interference). Total system reliability is also improved by shielding the main circuit board from the static produced by these high voltage bursts on start up. (not to mention they're damn good looking!)
HID Bulbs: At the heart of the XB H7 bulbs is their perfectly aligned 100% Philips Quartz glass that houses a capsule from APL-USA. Using high quality halide salts from German-supplier Messer; the bulbs produce nearly the same luminosity (intensity) as the amazing Osram CBI bulbs at 5500K. No, you're not seeing things here, but yes you will be seeing everything at night!
Wiring: The HD Relay Harness features an all-new completely sealed double 40A Relays, 14 gauge stranded copper wire wrapped in durable black tech-flex mesh that looks like a factory harness once installed. No cutting or splicing here: there are only five connections and they're all plug-n-play.
Canbus Compatible: The Standalone Canbus harness substitute is recommended for European vehicles that display "bulb out" error messsages. They contain a series of capacitors and resistors to trick the car into thinking nothing has changed and help you avoid annoying lamp-out warnings on the dash.
Benchmark: Morimoto. The Automotive Lighting Benchmark. We are globally recognized as the brand to beat. No other brand blends performance and genuine product quality quite like us. Our vast product line has something for nearly every application, and if not; our R&D department is capable of producing it in short order.
Specifications
INPUT: 9-32VDC
OUTPUT:85VAC 35/50W
MAX VOLTAGE:25kV (at start-up)
OPERATING TEMP:-40C to +125C
XB35 RATED LIFE:2500 Hours
5000K: Pure White (~3400 lm) 6000K: Cool White (~3200 lm)
Old Sep 13, 2015 | 02:23 PM
  #484
kuraishin's Avatar
c-300
Hey AZN,
Are there H7 Bulbs available, one of mine burnt out and need to replace the bulb. It was using your 5000k Series I got it in like 2012 so its been a while.
-Kura
Old Sep 13, 2015 | 03:18 PM
  #485
AZN Optics's Avatar
Originally Posted by kuraishin
Hey AZN,
-Kura
We carry Morimoto units now and can sell you the H7 HID bulbs. PM me your email and address and we can send you an invoice
Old Oct 2, 2015 | 12:25 AM
  #486
AZN Optics's Avatar
bump
Old Oct 18, 2015 | 03:02 PM
  #487
DapperStyle's Avatar
2014 C300
bump
My AZN Optics driver side w5w LED parking light has started flickering, does this mean it needs to be replaced? It is a bit over a year old.
Old Oct 18, 2015 | 03:11 PM
  #488
AZN Optics's Avatar
You have the older V3 design if it was that long ago. Shoot us an email at aznoptics@gmail.com with your username, email, and mailing address so we can look up your record to confirm and see if you're within warranty period
Old Oct 24, 2015 | 06:40 PM
  #489
2014 C300
Received the replacement V5 parking bulbs today and installed them. AZN Optics once again has provided fantastic service and quick delivery. Bulbs installed without issue and are nice and bright!
One quick question, should these flat V5 bulbs be installed vertically within the housing or horizontally? I currently have the vertically with each "bulb side" being left and right rather than top and bottom. If it doesn't matter I'll leave them as is.
Old Oct 24, 2015 | 06:50 PM
  #490
AZN Optics's Avatar
Doesn't really matter, those COB diodes are so bright and bezel free that output is near 360. It just looks like a big bright point of light.
Old Oct 24, 2015 | 07:03 PM
  #491
2014 C300
Perfect, thanks Mike. I'll continue to recommend you guys to everyone.
Old Nov 19, 2015 | 02:13 AM
  #492
AMG3.2's Avatar
C63 AMG, P30
Just placed my order for the 195 V5 in 5k. Just want to make sure these are indeed for the eyelid section of my C63.
Thank you!
Old Dec 28, 2015 | 02:08 AM
  #493
AZN Optics's Avatar
Hope everyone had a very merry Christmas and a safe new year!
Old Dec 31, 2015 | 12:58 AM
  #494
manny26's Avatar
2010 Mercedes c250 4matic
how much are LED's for the fog lamps for the 2010 W204 sport ?
Old Dec 31, 2015 | 01:01 AM
  #495
AZN Optics's Avatar
We have an H7 plasma LED conversion kit for there. Retail price $60.
Old Jan 31, 2016 | 03:33 PM
  #496
Neokiller309's Avatar
2009 C300 Luxury
I would like to give a huge thank you to AZN Optics. Great product and greater service. Stands behind their products and is great to work with.
10/10 would definitely recommend.
Old Feb 1, 2016 | 06:44 PM
  #497
AZN Optics's Avatar
Appreciate the feedback
Old Mar 16, 2016 | 12:51 AM
  #498
AZN Optics's Avatar
Have halogen reflectors and don't want to blind oncoming traffic with an HID conversion? Good call! We also carry full line of Morimoto Bi-Xenon projector retrofit kits from FX-R stage III and IV to Morimoto Mini Stage III!
Old Mar 16, 2016 | 01:15 PM
  #499
gwai_jai's Avatar
2010 C300 4MATIC
I have the corner illuminating fogs...does the LEDs dim like normal bulbs?
Old Mar 16, 2016 | 04:01 PM
  #500
AZN Optics's Avatar
No. These as LEDs are digital in nature, they do not have the power up/power down cycle you see with halogen bulbs. They are instant on and instant off. There are multi staged LEDs that simulate the power up/power down you see in halogen bulbs, but those will get pricier based on how many illumination steps.
