No one will install my tires!
Old Jun 10, 2011 | 01:20 PM
dudeitsmattx's Avatar
2013 C250 Sport
Ok so I went with 275/30/20 for my rear and everyone says that I will not be able to drive it because the rear fenders will be sitting on the tire. I have super sports and stretched 255/30/20 on the rear now
Old Jun 10, 2011 | 01:22 PM
xXHotelCrazyXx's Avatar
2008 W204 Sport
put your car on jackstands then take the tires off yourself...then go get the mounted
Old Jun 10, 2011 | 01:31 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
I'm sure there is more than one tire shop in your town.
2013 C250 Sport
What if when I take then home and put them on the fender is sitting on the tire
Old Jun 10, 2011 | 01:33 PM
2013 C250 Sport
But it looks close. What if it makes it so the car can't be driven
Old Jun 10, 2011 | 01:46 PM
tanktube67's Avatar
Then you have to pay again to mount the old tires back, by then you will know whats your next step, rolling the fenders or stick with 255
Old Jun 10, 2011 | 01:47 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
my 275s on 10s are stretched too, 295 is the flush size for a 10. If you cant find a place just take one side off and go mount and test fit the one side, you will know right away if it will fit. Put a block of wood a few inches thick under teh rear tire and lower with the jack slow, it will almost bottom and you will know if it clears. kinda a pain, any tire shop around me will test fit and bottom car for you no prob
Old Jun 10, 2011 | 01:49 PM
2013 C250 Sport
Do urs rub? And are u on supersports also?
Old Jun 10, 2011 | 02:15 PM
2013 C250 Sport
I'm at a friends shop now. He's almost done with a car then were gunna throw my car up and see what we can do
Old Jun 10, 2011 | 02:48 PM
im on 40mm backs w 19s not dropped by have dynamic ride control w paddles and it gets lower than stock. no rubbing but barely makes it. 285 rubbed. I think you said u had 45mm backs, u should be OK. what brand tire? hopefully a narrom brand
Old Jun 10, 2011 | 02:50 PM
2013 C250 Sport
They are Achilles
Old Jun 10, 2011 | 03:40 PM
Matt_Eurojerks's Avatar
w204 C300
Thumbs down
They are Achilles
I never understood how people are going to cheap out on the ONLY thing keeping you on the road....
Old Jun 10, 2011 | 04:12 PM
2013 C250 Sport
I only went cheap to make sure they fit. And they are on but hardly. Had to remove the carpet in the wheel well, and I'm going to need a minor fender roll. But its able to drive me around. When these tires are done ill be going with a good tire and a 275/25/20
Old Jun 10, 2011 | 04:14 PM
w204 C300
Old Jun 10, 2011 | 04:15 PM
2013 C250 Sport
Whatk?
Old Jun 10, 2011 | 04:29 PM
thats right you have 20s, you need to go w 25 rear and thats still bigger than the stock diameter. theres a conversion chart somewhere on rim size and tire size and you can compare that to stock to try and match the overall diameter. thats what I did so I wouldnt have height issues w the inner fabric. If you went w sumitomo or falkens you would be OK doing nothing w 25 series in back i bet. there isnt any tire shops anywhere near you that stock high performance size tires that can test fit? even a crappy shop that stocks the tires should test fit for you, even if you gotta slip them a 20 or something.
Old Jun 10, 2011 | 04:47 PM
2013 C250 Sport
I don't know, never asked. Owell the tires are on. When its time to buy tires 275/25/20 it will be. Also when I took the carpet out you can see where the 255/30/20 had rubbed it down to almost nothing so.. Owell you live and you learn right.
Old Jun 10, 2011 | 08:12 PM
no kidding, the 255 were rubbing the fabric huh? u never heard the rub on bottomouts? but like you say u live and learn, I redid a bunch of stuff for nothing too a few times cause of trial and error. BUT on the other hand it prob looks good as hell on the rear tho. Ive seen guys cutout the fabric section above the wheel arches and then rivet or use pop fasteners a piece of plastic from above to buy more room, should work for you too. You can prob find a pair of used 20s in 25/275 if you look on craigslist or ebay local and pick up for now, that would help alot. theres not much fender to roll on these cars, if it clears dont even bother just fix the wheel well. post some pics of the look. supersports w 20s, you got guts bro.
Old Jun 10, 2011 | 09:14 PM
Frnakito71's Avatar
C300, 93tt RX7, 88RX7 Vet, 83RX7
Come guys it been cover many times already!!! 275/30 will not work 275/25 is the way to go! that's what i have and it has been posted
the only brand that make that size is nitto invo...
Old Jun 11, 2011 | 12:31 AM
2013 C250 Sport
My 275/30/20 works! :p
Old Jun 11, 2011 | 06:02 PM
Frnakito71's Avatar
What did you do the fender and liner to make it fit????
Old Jun 11, 2011 | 07:49 PM
2013 C250 Sport
All I did was remove the carpet inside the fender. I'm going to roll my fenders this seek
Old Jun 11, 2011 | 07:50 PM
2013 C250 Sport
This week* only because I plan to go a little lower either with smaller rear pads or getting coilovers
Old Jun 13, 2011 | 12:05 PM
Frnakito71's Avatar
If you have use the 275/25 you would have done nothing to it!! But thats your choice
Old Jun 13, 2011 | 01:56 PM
2013 C250 Sport
Very true. Buf only one company makes that tire size. And they are $400 each. So its not really worth it. $800 for two tires or go with a 30 and just remove the carpet. It's not like you need the carpet in there
