Azn Optics = Legit HIDs!
Old Jun 26, 2011 | 02:02 AM
itsLoonie's Avatar
2012 E350 RWD
Here are some pics. Couldn't get any good pictures of the LED tails/brake/signal because they didn't come out so well, but I'll post up a vid if anybody requests. There should be some roaming around though.
BTW, I do realize one of my eyebrows are out. The passenger side wire decided to rip on me so I decided to just run one on both sides until I can solder the wires back. Doing that when I pull off my headlights and when I'm painting the housings as well.
The best picture I got of the rear signals which are the RED LEDs.
Old Jul 12, 2011 | 06:44 PM
rcsuarez's Avatar
2009 C300 SPORT
finally
Uploaded with ImageShack.us
Old Jul 12, 2011 | 06:48 PM
rcsuarez's Avatar
2009 C300 SPORT
btw.. last night my lights started flickering. well just the left one. i checked the connections and switched ballasts i guess i'll see tonight if it was just a loose connection or if the ballast has gone bad.
Old Jul 12, 2011 | 06:50 PM
rcsuarez's Avatar
2009 C300 SPORT
Old Jul 12, 2011 | 07:41 PM
IGB's Avatar
IGB
'08 C300 MM Pano
Originally Posted by rcsuarez
finally
Now, that is a perfect match between eyelids & headlights....
Are those the OEM fogs or are your lenses tinted yellow?
Old Jul 12, 2011 | 07:56 PM
rcsuarez's Avatar
2009 C300 SPORT
They're some mtec 3500k I think. Maybe 3k? I forget. I had them laying around and put them on. I wanted to go hId. But I had hid fogs on my last car and the bulbs I had ended up fading. Idk why but one bulb ended up being yellow the other more like a washed out one.
Anyways other than some flickering last night. I'll find out If the ballast was bad or just a loose connection.
If all is well and it was just a loose connection. Then these 8k hids. And eye lids are awesome. I
Old Jul 17, 2011 | 12:47 PM
  #32
AZN Optics's Avatar
SPONSOR/MBworld Guru
Keep me informed if you have any more issues. Make sure the wiring is fully seated.
Old Jul 20, 2011 | 07:01 PM
  #33
rcsuarez's Avatar
2009 C300 SPORT
hey mike, so i think that the bulb may be busted. i noticed when i turn on my lights there is a slight wiggle in one of the beams (when the lights are shown against my garage). it shuts off and flickers approximately every 2 minutes. i turn the lights on and off to get them to turn back on. could this be the bulb? i'm going to try switching the ballasts once again to see how that works. is there a warranty on the bulbs?
Old Jul 20, 2011 | 07:19 PM
  #34
AZN Optics's Avatar
Yes, there's a warranty so don't worry about that, but I just want to make sure if it's the ballast or the bulb that's the issue. Try switching either the ballasts or the bulbs and see if the problem follows either. Once we nail down the damaged component, I'll process a warranty ASAP.
Old Jul 20, 2011 | 11:35 PM
  #35
rcsuarez's Avatar
2009 C300 SPORT
Hey mike. It is the bulb. Just switched out the ballasts just now. Same problem.
Old Jul 21, 2011 | 02:20 AM
  #36
AZN Optics's Avatar
Ok, no problem. PM me your name and transaction ID and I'll look up your order and ship out replacement bulb
Old Jul 25, 2011 | 01:46 PM
  #37
Frnakito71's Avatar
C300, 93tt RX7, 88RX7 Vet, 83RX7
So Mike on your HID you dont need the
HID Error Cancellers - Mercedes????
Old Jul 25, 2011 | 01:49 PM
  #38
rcsuarez's Avatar
2009 C300 SPORT
totally legit. thanks mike for the replacement bulb. works wonders again. so far been installed for about a month. no problems just a bad bulb. 8k HID + LED eye lids. awesome buy!
Old Jul 25, 2011 | 02:32 PM
  #39
AZN Optics's Avatar
For my HID kits, the error cancellers are now built into the canbus ballasts to make install even easier.
Old Jul 25, 2011 | 02:59 PM
  #40
Frnakito71's Avatar
If i place an order right now how fast can youget them to me to 33146?
One of my 35W DDM HID igniter went bad on my last Saturday...
Old Jul 25, 2011 | 04:01 PM
  #41
AZN Optics's Avatar
Would be shipped out tomorrow morning and should take maybe 2-3 days to get to you.
Old Jul 25, 2011 | 05:21 PM
  #42
Frnakito71's Avatar
Can you paypall me at frankiea@cheneybrothers.com
Old Nov 12, 2011 | 12:05 AM
  #43
FactoryRaceCar's Avatar
2011 E550, 2010 E350 and 2009 C300
Mike is there a phone number where you could be reached? I need to place an order. I tried website but it's not working for me?
You can PM me the information if you want.
Thanks!
Old Nov 12, 2011 | 12:09 AM
  #44
AZN Optics's Avatar
Thanks!
Send an email to aznoptics@gmail.com with your inquiry
Old Nov 12, 2011 | 12:15 AM
  #45
Ok, I will do that. Thank you!
Old Nov 13, 2011 | 09:53 AM
  #46
CKreep's Avatar
C300
How much for a 5K kit for an 09 c300?
Old Nov 13, 2011 | 12:18 PM
  #47
AZN Optics's Avatar
Hid kits are $100/kit + shipping.
Old Nov 14, 2011 | 03:50 AM
  #48
vanitr's Avatar
W204
The HID's look awesome! I would def get one of AZN's kits if my car didn't already come with HID's.
Old Nov 15, 2011 | 04:15 PM
  #49
Mike I am ready to place an order for low beams on my 09 C300. How close is your 5000K kit to factory Xenon 4300K? Is it more like 4300K?, 6000k or in between? How far off the factory eyebrows will be with your 5000K kit? I really don't want the 6000k look but more like factory look.
Old Nov 15, 2011 | 05:38 PM
  #50
AZN Optics's Avatar
My 5000K HIDs are close to 4300K, but will be more of a pure white. 4300K still has a bit of yellow to it.
