Old Jun 16, 2015, 02:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Ambient light stuck on help!
Old Jun 25, 2011 | 12:46 AM
rage187u's Avatar
C230 kompressor
Does this light only go off if i lock the door with the button on the key, if i manually lock the door the light stays on and everything ive read says its supposed to go off my button on my key doesnt work !!
Old Jun 25, 2011 | 01:23 AM
RedVines's Avatar
'11 Mercedes Benz C300; Black on Black 7g-tronic, Nav+4 uni
what do you mean when you say manually lock the door? because i know the ambient light will turn off with time when you close the door... And if you do leave interior lights on, when you do lock the door using the key all lights shut off inside.
Old Jun 25, 2011 | 08:58 AM
rage187u's Avatar
C230 kompressor
The button on my key to lock the door doesnt work but you can pull the the actual metal key out of the back of it and manually lock the door that ambient light was on for hours last night
Old Jun 25, 2011 | 09:02 AM
JFOUR's Avatar
2008 C300 Sport 6MT X-Pipe
Not sure which light you are asking about. The ambient lighting (over the door handles) in my car stay on for about 30 mins after closing the doors, whether the car is locked or not.
Old Jun 25, 2011 | 09:04 AM
rage187u's Avatar
C230 kompressor
Its the amber light coming from under my mirror
Old Jun 25, 2011 | 09:26 AM
rage187u's Avatar
C230 kompressor
Im sure its not hot enough to hurt anything but it stays on for a long time
Old Jun 25, 2011 | 10:44 AM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
That long? Mine turns off in like 5 minutes.
Old Jun 25, 2011 | 10:50 AM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
See the owners manual. You can configure whether or not you want the vehicle lights to remain on or not. If the feature is on, I believe the time until the lights go out is 60 seconds. You can change this in Settings in the Instrument Cluster using the steering wheel buttons. Good luck
Old Jun 25, 2011 | 11:16 AM
rage187u's Avatar
C230 kompressor
I tried that theres no setting for the ambient light
Old Jun 25, 2011 | 04:03 PM
C300CA's Avatar
I went to my dealer asking the light control question. The advisor does not know much about light enable or disable. While there, I found:
(1) sit in and close all doors, turn the key to position 1, disable interoir light. When I pull key out, the dome light does not turn on at all. When I open and then close the door, dome light turns on and stay on for 10 seconds.
(2) do the same but enable interior light. When I pull key out, dome light turns on ans stay on for 10 seconds. When I open and then close the door, dome light turns on and stays on for 10 seconds.
To me this enable/disable is almost useless.
Old Jun 25, 2011 | 04:15 PM
rage187u's Avatar
C230 kompressor
Lol ya i dont get it i mean the ambient light doesnt bother me as long as it doesnt hurt anything in the car i mean its a tiny amber light so i wouldnt think it would but i mean if it never goes off wtf ya know lol!
Old Jun 26, 2011 | 07:00 AM
JFOUR's Avatar
Yup. They stay on for a good 1/2 hour . I'll have to look and see if the light under the mirror stays on too.
