Attention about w204 engineering menu(REMAINING CHANGES RESET)
Hi every one
WHEN YOU CHANGE THE MODE TO JAPAN THE COMBINATION TO THE COMAND MENU CHANGES FROM :HANGUP+1+# TO: (PICKUP BUTTON +1+#) and then finally i found out how to reset the remaining changes on the comand once you have exceeded the limit when you go to the engineering menu you go to (HW SETTINGS THEN HU PARAMETERS THEN DVD/MARKET SETTINGS THEN GO ALL THE WAY DOWN AND HOLD THE COMMAND WHEEL TOWARDS THE BACK SEATS AND IT WILL GO TO THE SECOND PAGE THEN IF YOUR COMAND IS IN JAPAN MODE PRESS PICKUP BUTTON +*+# AND IF YOUR COMAND IS IN ECE OR US MODE HOLD HANGUP BUTTON+*+# FOR 8 SECONDS THEN THE REMAINING CHANGES WILL BE RESETED AND WILL GIVE YOU 5 MORE ATTEMPS) I HOPE THIS HELPS:y |
hello every one can somebody tell witch one is the Hangup button and the pickup button
Originally Posted by abed123
(Post 6027570)
i would assume its the one that has a red phone for hang up, and green phone logo for pick up. |
what can you do in the engineering menu?
Originally Posted by Sinakokabi
(Post 4771316)
Hi every one
WHEN YOU CHANGE THE MODE TO JAPAN THE COMBINATION TO THE COMAND MENU CHANGES FROM :HANGUP+1+# TO: (PICKUP BUTTON +1+#) and then finally i found out how to reset the remaining changes on the comand once you have exceeded the limit when you go to the engineering menu you go to (HW SETTINGS THEN HU PARAMETERS THEN DVD/MARKET SETTINGS THEN GO ALL THE WAY DOWN AND HOLD THE COMMAND WHEEL TOWARDS THE BACK SEATS AND IT WILL GO TO THE SECOND PAGE THEN IF YOUR COMAND IS IN JAPAN MODE PRESS PICKUP BUTTON +*+# AND IF YOUR COMAND IS IN ECE OR US MODE HOLD HANGUP BUTTON+*+# FOR 8 SECONDS THEN THE REMAINING CHANGES WILL BE RESETED AND WILL GIVE YOU 5 MORE ATTEMPS) I HOPE THIS HELPS:y MY CAR DO NOT HAVE NAVIGATION AND I AM GET TO THE MODE HU THE I PRESS THE COMAND BUTTON IT WILL GIVE OPTION NEXT OR BACK I PESS NEXT I GET IN TO PAGE HAVING IFORMATION ABOUT THE VIRSION AND THAT SHOWING USA I AM TRYING TO HOLD THE RED BUTTON +*+# BUT NOTHING IS HAPPEN ALSO I CAN GO TO THE PAGE WITH THE RADIO OPTION FOR FM AM AND ANTENA I PRESS ON ANTTENA IT WILL GIVE OPTION TO SEARCH THE FREQUENCY I CAN GET THE STATIONS AND LISTEN TO THE BUT WHEN I TURN THE CAR OFF FOR ONE OUR I LOOSES THEM AGAIN ??? SO PLEASE ANY BODY CAN TELL HOW I DO SAVE THE SATATIONS??? THANKS |
(Post 6033901)
Okay first off. Look at your keyboard which should look like this. http://www.wpclipart.com/computer/ha...oard_black.png Next make sure your CAPS LOCK button is off!!!!!!!! http://www.logitech.com/assets/49284...oard-tk820.jpg Next step is to go here and read the manual. http://www.mbusa.com/mercedes/servic...owners_manuals |
Originally Posted by Andriy242
(Post 6034320)
http://www.wpclipart.com/computer/ha...oard_black.png Next make sure your CAPS LOCK button is off!!!!!!!! http://www.logitech.com/assets/49284...oard-tk820.jpg Next step is to go here and read the manual. http://www.mbusa.com/mercedes/servic...owners_manuals LOL!!!! :rolf: |
I like to read cd counterfeit think when you enter the menu I disable that option and no longer reads
Hi there
I am unable to log into the menu either. I have a 2007 CL 550 |
Originally Posted by nz1otter
(Post 6691412)
Hi there
I am unable to log into the menu either. I have a 2007 CL 550 W204 has the NTG4 and NTG4.5, your car has the NTG3 |
(Post 6034320)
Nassr
(Post 4771316)
Hi every one
WHEN YOU CHANGE THE MODE TO JAPAN THE COMBINATION TO THE COMAND MENU CHANGES FROM :HANGUP+1+# TO: (PICKUP BUTTON +1+#) and then finally i found out how to reset the remaining changes on the comand once you have exceeded the limit when you go to the engineering menu you go to (HW SETTINGS THEN HU PARAMETERS THEN DVD/MARKET SETTINGS THEN GO ALL THE WAY DOWN AND HOLD THE COMMAND WHEEL TOWARDS THE BACK SEATS AND IT WILL GO TO THE SECOND PAGE THEN IF YOUR COMAND IS IN JAPAN MODE PRESS PICKUP BUTTON +*+# AND IF YOUR COMAND IS IN ECE OR US MODE HOLD HANGUP BUTTON+*+# FOR 8 SECONDS THEN THE REMAINING CHANGES WILL BE RESETED AND WILL GIVE YOU 5 MORE ATTEMPS) I HOPE THIS HELPS:y Thanks alot i was take my car to the dealer they dont no what is engineering mode 😳 Thanks alot |
1 Attachment(s)
Hi,
I have changed the region from Japan to ECE and the Radio is blocked, see attachment, any clue guys? |
Thanks!!
Worked a treat for me...:)
Thanks i was able to revert my changes back to original and the Anti theft is gone for me.
Originally Posted by mms2209
(Post 7464730)
Thanks man you are the best, you solved a big problem to me
Engineer Mode.
Hi, I noticed in the EMC mode that the FAN(internal) and FAN(external) are both off, is this correct and which FANs are they talking about?
Thanks |
Originally Posted by salman002
(Post 6979991)
Hi,
I have changed the region from Japan to ECE and the Radio is blocked, see attachment, any clue guys? I am having the same issue. Thank you in advance. |
(Post 4771316)
Hi every one
