w204 lowering springs
w204
hey guys,
i'm planing to get lowering springs installed so doing a lit research.
i used to have tein installed on my audi and liked it much. eibach is very famous for w204 here in korea but i have never used eibach before.
anyways, just want some feedbacks among these four
1. eibach
2. h&r
3. kw
4. tein
thanks guys,
1. eibach
2. h&r
3. kw
4. tein
thanks guys,
All are good brands...be aware of Tein knock-offs. I have H&R super sports on my junk with 5mm pads in the rear.
What kind of wheels are you running? I just got back from my visit to Korea and honestly, unless you're in the countryside, roads there are fine enough that even a low drop won't' cause worries.
I'm currently running Eibachs with 5mm rear spring pads and I couldn't be happier. (Now if only I could get a decent alignment going).
01' c320 (sold) / 03' Ford Focus(sold) :( / 98' C230 / 00' SL500 / 11' C300 Sport RWD w204
i have a set of H&R supersport i bought off Rob from this forum (he lives around my area) but ended up not using it cause I decided to go with coilovers (gonna be running 20's and I dont wanna rub). PM me if you're interested
C300
I have H&R Sport Springs with 5mm pads i bought of Alex (snarlingchicken) couple of months ago. just got them installed last week; I like them but will probably change them out with Super Sports, just to go a little lower .
Thanks Alex!
-Chris
Thanks Alex!
-Chris
w204
to snarling, i'm running 235/35/19 and 255/30/19, any recommandations?
is 5mm spring pad a must have? or just better off to have?
i'm worried about the front, i realized the front tires hits the fender when i'm on high speed on bumpy highway.
so guys, if you were to get new lowering springs, would you get the one you are using right now? or try something else?
But if you're tires are rubbing on the highway, I might urge you to maybe get new wheels or tires....what are your offsets and what kind of wheels are you running? I absolutely pray that you didn't buy wheels from those tire shops off the side of the road that carry knock-offs of BBS....
Anyways, if I had the option of going lower, I think it would depend on the wheels I had. Most likely I would just opt for a nice set of 18" Forgestars or something, and stick with my Eibach's, but more than likely, if I opted for a set of 19"s, I would see if I could hold out for a set of coilovers.
C300
I just got my wheels about a week ago and before then, i decided to wait till before the wheels were about to go on to lower the car. The wheels will be on on wednesday
I've got H&R -20mm from AMG pack which is -15mm from stock. Front is very nice with 19th, no space at all. Rear not that good, 2 fingers approximately.
Ml 320 cdi SPORT W164 / C W204 / Mini cooper
I really wanna put eibach or H&R but i've heard about some problems with the original coilovers! Some guys have destroyed them after 15k miles..
Is that true??
Is that true??
4matic C300
I know everyone has said to go with Supersports but have you done this on stock shocks. Also what is the ride quality like. Near stock "sport model" or like the ricer that bounces 16 times when it hits a road bump
2014 C63 AMG 507 sedan
Ricers bounce because they use low quality struts with low quality springs, or worse, cut the springs.
A quality OEM strut with quality springs (H&R, Eibach, etc.) should be fine.
I just ordered H&R Sports for my C300 4matic, can't wait to get them on!
I realize that this is pretty late so I am hoping someone has an answer for me... so these pads are completely optional? I am looking to lower my w204 c350 with H&R super sports. 1.8" in the front 1.7" in the back...
I have never lowered any of my cars. What is the purpose of these pads and if its required really is my question..
