Rattling from around the glovebox area (audio clip included)
W204 C180 Avantgarde
It's most noticeable when braking to a full stop, but I can also hear it slightly when driving. It doesn't seem connected to the suspension.
I've heard a similar rattling in my old 91 BMW E36 and that came from a sort of shielding connected to the brake disc - but that doesn't seem to be the issue here. I've tapped all around the cabin in the front passenger side, but I can't provoke the sound.
I've recorded the rattling which can be found here: https://rapidshare.com/files/1069326...d_10th_sek.wav
The rattling in the recording isn't as loud as the sound actually seems. It can be heard between the 8th and the 10th second and sounds like an old refrigerator turning off.
Does anyone have an idea as to where it can come from and what it can be?
As an update, I can say that the rattle/sound also comes when sitting in the car after driving, with the engine turned of but the key in 2nd position. You can hear a few small electric buzz-like sounds and then the rattle comes twice from behind the glovebox.
Does anyone have an idea?
Overview of components
Does anyone have an overview of the components included in the dash/behind the glovebox, so I can see, what might be loose back there? BMW has something similar to what I'm thinking of called an ETK ( in english: EPC)
DanielUK1 has in this thread: https://mbworld.org/forums/c-class-w...ml#post4796439 guided me to this thread; http://www.benzworld.org/forums/w204...-glovebox.html which seems to be the exact problem that I have.
If anyone have a problem similar to me, then look it up on the link above.
2012 C250 Coupe
Honestly, I don't think you are going to be able to find detailed information like that on this forum (though, I could be wrong). I think if you are under warranty your best bet is to go to the dealer and complain, these rattles and things are covered.
But I'll just have to go back and push for them to fix it.
Could I be correct in saying that you have a right hand drive car ?. You do not mention where you are from.
In my RHD car the interior fan is just behind the glovebox . You should be able to lift the fan cover & inspect to see if it spins freely or whether it has some debris in & around it.
Also open the bonnet & listen for the sound.
If all else fails try removing the glove box . I think there is a "how too' on this forum..
I think the thread, which DanielUK1 referred me to, is spot on. It might very well be an A/C flap motor under the dash, but neither the less, I'm going to try the things you recommend, before taking it to the dealer - but I'll let them disassemble the glove box if necessary.
I don't even know if this is remotely related but it does mention "Model 204 Noises from Vicinity of Glove Box"
I dont even know where you can look up more info on it, but its worth pursuing if you end up at a dealer to check it out!
TECHINICAL SERVICE BULLETIN: LI83.00-P-048144_Ver.1
MFG Bulletin Date: 12-07-2009
Component: Body
Bulletin Summary: Revision: Content updated to provide more detail / Supersedes DTB P-B-83.30/122a Model 204 Noises from Vicinity of Glove Box
Date added to database: 03-11-2010
Now you can receive the same Full TSB Content that Dealers get for ALL Service Bulletins ever issued for this model car plus ALL Bulletins issued for the next 12 months.
Component: Body
